Emcoturn 120 lathe retrofit
10 years 3 months ago #77256 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
andypugh wrote: I would make X home switch 0, home position -0.1 and negative travel max -8 and positive travel max -0.1, I think.
(Because PnCConf won't let you change the home switch location)
modified page
10 years 3 months ago #77257 by LutzTD
I duplicated the x on the z with smaller axis length value
next window is the spindle
my encoder has an A channel, a B channel and an Index, 1800 pulses
I assume the direction is called by a pin, not by pos,neg voltage
10 years 3 months ago - 10 years 3 months ago #77258 by LutzTD
sorry repeat
Last edit: 10 years 3 months ago by LutzTD.
10 years 3 months ago #77260 by andypugh
LutzTD wrote: I duplicated the x on the z with smaller axis length value
That seems wrong, and I thought that 8" cross-slide travel seemed a bit much for an Emco.
Z is saddle, X is cross-slide.
And both mills and lathes the Z axis runs along the axis of the spindle.
10 years 3 months ago #77261 by LutzTD
yeah I had it backwards. I will fix it
10 years 3 months ago - 10 years 3 months ago #77435 by LutzTD
I was able to get the toolchanger working. over the past couple weeks its been quite a battle learning and implementing the programming to make the toolchanger turn on command T1 M6. I got that working 2 days ago. then spent another couple days getting it to work with buttons on GUI. But success last night.
