I am retrofitting an Emcoturn 120 lathe. I have stripped the machine and cleaned it and am in the process of reassembling it and designing the control. Initially I was planning to us Mach, but I would like to explore all options. I am not familiar with any part of the process to install and configure linux OS or linuxcnc, so hopefully I can ask enough of the right questions to determine if this is something I can handle. I am an ME, but haven’t really done anything but basic step by step programming. I have an understanding of the general structure but no clue of the nuts and bolts of programming.. Anyway, here is the basic outline of the system I had planned using Mach, hopefully there is an equivalent or better system design I can use in linuxcnc
1. COMPUTER. Dell FX170 Thin Client 1.6Ghz 2GB, 1GB Window Embedded Standard Desktop Computer. For Linux I think this same computer was available with a linux OS, but I think if possible I would like to keep the windows embedded intact, maybe boot linux from USB?
2. GENERAL INPUT/OUTPUT. I was planning to use a smoothstepper with a CNC4PC C32 - DUAL PORT MULTIFUNCTION CNC BOARD This has relays, e-stop control and a charge pump along with a very nice rj45 setup for wiring inputs. Also supports spindle speed control through a VFD.
3. TOOLCHANGER CONTROL. Plan to use the Toolerator 3000 PCBA copied from user tome on this forum.
4. SPINDLE. I have replaced the DC spindle motor with a 5hp 3phase ac motor, I will used a VFD to drive this. I plan to use a CNC4PC C3 PULSE INDEX CARD for the spindle speed sensor. I would like to add a brake for the spindle eventually. (assume through VFD).
5. AXIS. I plan to use the stock Berger-Lahr 5phase steppers with Vexta UDX5128NA drivers.
