Emcoturn 120 lathe retrofit
- LutzTD
29 Apr 2016 12:08 #74053
by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
looks like this box uses DOM "disk on module" memory. I found a 8GB drive on ebay for $27. I offered them $22. Im getting less exited about the FX170......
29 Apr 2016 12:19 - 29 Apr 2016 12:19 #74054
I use those, I like them for CNC boxes.
You need to be slightly careful when handling the motherboard with the DOM fitted, or you snap off the SATA connector and have to do this to rescue the data and config
Replied by andypugh on topic Emcoturn 120 lathe retrofit
Last edit: 29 Apr 2016 12:19 by andypugh.
- LutzTD
29 Apr 2016 14:16 #74057
by LutzTD
Im feeling like Im reinventing the wheel. what is the best compromise for cost size and fanless cooling? Am I on the right track with this box?
29 Apr 2016 14:19 #74058
If the box you have has decent latency when running linuxCNC then it will be fine.
You really should try that test.
- LutzTD
29 Apr 2016 15:20 #74059
by LutzTD
I thought I would try the install but it ran out of space so Ill try again tonight running from the thumbdrive
- LutzTD
29 Apr 2016 22:00 #74073
by LutzTD
ran it today when I got home from USB.
servo 1ms 26629
base 25us 27045
servo 1ms 26629
base 25us 27045
30 Apr 2016 01:19 #74078
Good numbers, but that was probably RTAI whereas for an ethernet card you need uspace (still new, forgot to mention that)
linuxcnc.org/docs/2.7/html/getting-start...th_preempt_rt_kernel
- LutzTD
30 Apr 2016 17:31 #74088
by LutzTD
this was running on a USB. I went ahead and got the 8GB DOM since they agreed to the $22 price. SHould see it late next week and Ill load it to the DOM and run it.
- LutzTD
06 May 2016 02:59 #74286
by LutzTD
question about linuxcnc. With Mach3, when I wish to tweak a hole or profile size I have to go back to my CAM package and change the tool diameter or roughing clearance and regenerate the cut. Does linuxcnc work in a similar fashion or is there a way to offset a path by a couple thousandth as needed? I assume no which is an issue for me as I run my cam and mach on the same computer. Is there a good cam package that can run on the linux box along with the linuxcnc?
06 May 2016 08:38 #74291
I think that both Mach and LinuxCNC can do tool compensation in the controller or in the CAM system. If you do the compensation in the controller then you can tweak the tool diameter to tweak hole sizes.
If, however, the compensation is in the CAM system then the G-code is a tool-centre path and the controller doesn't actually "know" which side of the tool path the material is on, so can't compensate.
Time to create page: 0.797 seconds
