Emcoturn 120 lathe retrofit
10 years 6 months ago #73979 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
the toolerator 3000 is a PCBA and programming for linuxcnc ans arduino to operate the emco toolchanger done by user tome here on this board.. A more detailed explanation is here in this thread forum.linuxcnc.org/forum/26-turning/2928...-tool-turret-control . I have already sourced pcbs and built a toolerator 3000 pcba which I planned to use either with linxucnc or mach.
10 years 6 months ago - 10 years 6 months ago #73984 by tome
Replied by tome on topic Emcoturn 120 lathe retrofit
Todd Zuercher wrote: I am completely ignorant of your tool changer arrangement, and the need for the "Toolerator 3000" and exactly what it does. How did the original control operate the tool changer, and what might be the difficulties of reusing the old systems?
The tool turret on the EMCO 120P uses a brushless DC motor connected to a worm gear that drives the turret. There is a gray code encoder that reads the tool position. The original controller would take the change tool command with tool number,, turn the turret just past that tool position (based on the reading of the encoder) and then back the DC motor up at which point a spring loaded pawl stops the turret at that position. The current to the motor is dropped to hold the motor in that position without overheating it.
The Toolerator 3000 is an Arduino and LMD18245 motor driver based version of that controller logic. It takes the tool change from Linuxcnc via USB port and reads the encoder and appropriately controls the motor. It is one of several controllers for the EMCO (and other) turret. It is specfically set up for Linuxcnc but I am sure it could easily be commanded from Mach if need be.
-Tom
Last edit: 10 years 6 months ago by tome.
10 years 6 months ago - 10 years 6 months ago #73985 by tome
Todd Zuercher wrote: CW/CCW is an abbreviation for ClockWise/Counter ClockWise. and I think that those drives use that input system. The drives expect step pulses on the CW input to turn clockwise, and pulses on the CCW input to turn counter-clockwise.
The Vexta drives take step/dir. I can post my config files if you'd like to see them. I am using a different set of hardware (6i25, 7i84 and 7i85s) but they would give you the idea...
-Tom
10 years 6 months ago #73987 by tome
BTW, I don't know how much information you have on your lathe but I have accumulated a significant amount of information (much in PDF form). If you'd like I can post it here (or elsewhere)...
10 years 6 months ago #73992 by andypugh
LutzTD wrote: I am a newb so forgive me if it sounds like I have my heart set on the smooth stepper or the C32 PCB. Its just what I know so I use that as a baseline.
Thinking about this a little further, you should definitely use LinuxCNC for this lathe, because it is a lathe. Mach3 is perfectly adequate for milling machines, but has well-known shortcomings for lathe control. This is why Tormach switched to LinuxCNC when they started to make a lathe. The main difference is that Mach3 does not slave the Z axis to the spindle encoder when threading. This means that even if the spindle slows during a threading pass the thread pitch is unaffected. You can even stop the spindle during the threading pass and it keeps synch:
Mach3 can do external threading reasonably well as long as the spindle speed does not change, but it can't really do rigid-tapping. which is where the spindle is reversed at the bottom of the pass and the tap is backed-out. Mach3 can "fake" this with a servo spindle by making coordinated spindle and Z moves, but I don't think that the Emcoturn has this degree of spindle control.
Normally I don't make any specific recommendation between LinuxCNC or Mach3, the choice should be down to the user, but for a lathe I believe there are good arguments that LinuxCNC works better.
10 years 6 months ago #73999 by LutzTD
tome wrote: BTW, I don't know how much information you have on your lathe but I have accumulated a significant amount of information (much in PDF form). If you'd like I can post it here (or elsewhere)...
Would be nice for me to have any info attached here. I have a few things but not much of the detailed stuff. Of course since its gutted maybe most of the detail no longer applies but it would be good reference for system architecture. Along with that anything you want to share in the way of your retrofit setup and linuxcnc code certainly would help. It sounds so far like I can get better functionality at a lower initial cost with a linuxcnc system, Im just worried that 5 years from now if something goes wrong I will need to relearn everything., but it sounds like its worth the risk. Maybe the next lathe or mill retrofit (id like to do a large vmc with a toolchanger if I can find a dead control HAAS or mazak for cheap) will keep me up to date or even increase my knowledge base instead of forgetting it later.
Time to create page: 0.173 seconds
