LutzTD wrote: question about linuxcnc. With Mach3, when I wish to tweak a hole or profile size I have to go back to my CAM package and change the tool diameter or roughing clearance and regenerate the cut. Does linuxcnc work in a similar fashion
If you write your G-code without an offset for the tool radius, you can then use G42 or G43 radius offsets to make the CNC control offset its path by the tool's radius. By adjusting the tool diameter in the tool table, you can alter the path by small amounts to bring parts exactly on size, and compensate for tool wear.LutzTD wrote: question about linuxcnc. With Mach3, when I wish to tweak a hole or profile size I have to go back to my CAM package and change the tool diameter or roughing clearance and regenerate the cut. Does linuxcnc work in a similar fashion or is there a way to offset a path by a couple thousandth as needed? I assume no which is an issue for me as I run my cam and mach on the same computer. Is there a good cam package that can run on the linux box along with the linuxcnc?
