- Thank you received: 126
Probably CAMBAM can be set to generate toolpaths without the radius offset built into the G-code. A gross way to do this would be to tell it the tool has zero diameter, but that is pretty awful. I know how to do this in Bobcad/CAM, but that might be a much more "hands on" g-code generator than CAMBAM. In the old days, before I was confident in what I was doing, I'd mount a ballpoint pen in the spindle and run the program with tool diameter set to zero, and it would draw the part outline on paper. Then, I would use one program to rough and finish. I'd set the tool table to show a larger diameter than it actually was, and it would do a roughing cut. Then, I could set the actual tool diameter and the same program would make the finishing cut.LutzTD wrote: Hi Jon, yeah I dont write the code. CAM solutions are so cheap now there is no reason to write code. I use a program called CAMBAM which is working extremely well for me. I have been remiss in looking to see if it is available in Linux form. The CAMBAM code has the tool compensation in it already, so editing the code simply would not work. What I can do right now is leave the CAMBAM window open and tweak the tool diameter to size holes. I was looking for a CAM software that could run concurrent with the Linuxcnc to be apples to apples. I dont want to be editing raw code.
