Emcoturn 120 lathe retrofit
10 years 4 months ago #75356 by andypugh
LutzTD wrote: I need to get the Mesa PCBA from the package as the schematic and the manual do not show where the Jumper 1 location is for sure.
Look at the picture on page 5 of the manual. W1 is jumper 1.
10 years 4 months ago - 10 years 4 months ago #75370 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
thanx I see it now, Ill update my graphic tomorrow. I want to show the settings of all of the jumpers in my build spreadsheet to make sure I get them all right before I connect it to power.
EDIT: jumpers
Last edit: 10 years 4 months ago by LutzTD.
10 years 4 months ago #75372 by LutzTD
I removed the 5vdc PSU and mounted the ginormous 70A motor starter. Also configured 2 sets of contacts. It looks so disjointed because there was only about 14 inches of 35mm din rail and then the contact rails were another size, then the ones in the lathe were another size. I have some din rail coming but likely the components wont all line up anyway and Ill cut individual mounts. I have also received the BEI encoders I ordered, (got 2 different ones to see which will work better) Ill have to make a shaft adapter this weekend rather than buy a different pulley.
10 years 4 months ago #75408 by LutzTD
power wiring simplified a little more. the 24vdc psu has 2 sets of output terminals which is all i need so the extra terminal blocks go away
10 years 4 months ago - 10 years 4 months ago #75435 by LutzTD
I was doing more detail layout of the Automation Direct VFD and have hit a snag. The 5hp version of this drive is 3ph input only. Does anyone have experience with the Huanyang inverters on Ebay? Looks like the 5hp and the 10hp versions allow 1ph input. The ebay advert shows quite a few beig sold, just wondering if anyone has experience. Should I go with the 5hp or up it to 10hp to get less stress on the VFD?
10 years 4 months ago #75436 by andypugh
LutzTD wrote: I was doing more detail layout of the Automation Direct VFD and have hit a snag. The 5hp version of this drive is 3ph input only. Does anyone have experience with the Huanyang inverters on Ebay? Looks like the 5hp and the 10hp versions allow 1ph input
You can see if the AD drive works on single phase. It might well do. You should probably de-rate somewhat, but to be honest you are unlikely to hit 5hp during normal turning activities.
I have the 5hp HY VFD on my lathe, and it seems to work nicely, and was very easy to configure with (It's own special variant of) Modbus and a USB to Modbus dongle using the LinuxCNC hy_vfd component.
Time to create page: 0.496 seconds
