Emcoturn 120 lathe retrofit
10 years 5 months ago - 10 years 5 months ago #75305 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
here are my thoughts on the power wiring. what recommendations for fuses at these locations? Or are the locations wrong? I was planning to use the 25A ceramic holder/fuses in position 1 and the 6a/leg breaker in the "breaker" location but now I think these may be too large a value.
Last edit: 10 years 5 months ago by LutzTD.
10 years 5 months ago #75306 by andypugh
I don't have any actual fuses in my system, I use MCBs throughout. They are so cheap that it seems pointless not to.
I have a single 20A for the motors and two 3A ones for the switched and unswitched low-voltage supplies.
So, there is a 3-pole isolator switch (with only 2 poles in use) feeding a single 3A breaker and the main contactor. That breaker feeds a 24V supply for GPIO (and the main contactor) and a 12V supply for the PC. The main contactor then powers the 20A breaker for servo and spindle power and a second 3A breaker for the spindle gearbox clutches and brake.
The 20A breaker is C-rated for motor use. The 3A ones are not, but soon will be, as the 3A B-rated type tend to trip on the inrush current of the PSUs.
10 years 5 months ago - 10 years 5 months ago #75308 by LutzTD
so I would want to ?
replace fuse 1 with 2 pole or 3 pole 20amp/pole MCP, how do I know if it is c rated?
replace "breaker" with 2 pole 3A/pole MCB
replace "5" with 2pole 10A/pole MCB
get rid of 2,3,4 and 6.
10 years 5 months ago #75312 by andypugh
LutzTD wrote: replace fuse 1 with 2 pole or 3 pole 20amp/pole MCP, how do I know if it is c rated?.
It says on the front. (well, it does here, things might be different where you are).
www.tlc-direct.co.uk/Main_Index/Consumer...ssories_1/index.html
There are types A and D too, but you rarely see them.
A bit of extra detail: www.tlc-direct.co.uk/Technical/Distribution/Mcb.htm
The following user(s) said Thank You: LutzTD
10 years 4 months ago #75318 by LutzTD
thanx, I also did a little research. I like to stick with names I know when it doesnt cost too much more. I ended up getting 3 double pole breakers made by Allen Bradley, a 1489-A2C200, 1489-A2C100 and a 1489-A2C030, which are 20A, 10A and 3A respectively. The third digit "C" in the second part of the number designates the C rating, ( I downloaded the catalog to find this out) These are from surplus dealers on ebay. They were about $15 each for NOS units, so not too much different.
10 years 4 months ago #75341 by LutzTD
I like to work in graphics to wrap my head around it, so here is my power layout
Time to create page: 0.321 seconds
