- Thank you received: 7491
Brother TC-225 / TC-229 adventure!
9 years 8 months ago #87609
Replied by tommylight on topic Brother TC-225 / TC-229 adventure!
I used this, easily modifiable and exactly what i needed it for.
I had the same feedback but with mechanical switches.
Regards,
Tom
Regards,
Tom
9 years 8 months ago #87621
Yes, we have a HAL component for exactly this purpose:
linuxcnc.org/docs/devel/html/man/man9/carousel.9.html
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
ihavenofish wrote: i assume it should be pretty easy for linux to read 4 inputs and then turn their binary values into a number right?
- ihavenofish
- Thank you received: 286
9 years 8 months ago #87623
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
sweet! that seems to be exactly what we need here.
thanks.
thanks.
- ihavenofish
9 years 8 months ago #88066
by ihavenofish
well the machines have arrived. i need to have a 220v 3 phase plug wired, and i can plug the first one in and see whats going on. initial inspection suggests its in good shape.
- ihavenofish
9 years 8 months ago #88132
by ihavenofish
chips! sady, not new ones. haha. yup, they are a bit filthy, but ive gone over them some more, pulling way covers off and they seem in good mechanical shape. dont feel any play, doesnt seem to be any backlash manually turning the screws on the x and y.
im pleased so far. ive determined that both machines should turn on, as is. so, that is the next step. still waiting on the plug wiring.
fun fun.
fun fun.
- ihavenofish
9 years 8 months ago #88157
by ihavenofish
so, to the second machine for a moment. the tc229. ive found that the servo drive use 2.5mb/s rs422 serial communication. it suggests its a proprietary 6 byte data block. i assume it transfers both encoder and command, and other data in those 6 bytes.
any thoughts on if this could be deciphered and made to talk to linuxcnc? i can find some basic info on the chip, but not much detail yet. the interface chip is called sanyo ga1022, and is both on the motherboard and in the drive.
Time to create page: 6.721 seconds
