Brother TC-225 / TC-229 adventure!
9 years 8 months ago #88763
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
DC resistance might not be one of the most important characteristics.
It's probably difficult to work out what the coil inductance and moment of inertia are, but they are likely to be in there.
- ihavenofish
- Thank you received: 286
9 years 8 months ago #88766
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
inertia is in the spec sheet, but the numbers dont relate to any in that list - at least not directly. but being hex, you dont know if any of the byes are a sign, a decimal, etc. so it could be a bad translation. i suspect inertia between the new and old motors will be nearly the same. same shaft diam, same size. old motor is a few mm longer. inductance isnt in the spec sheet. it does have KV, torque constant and a few other (going by memory here, ill link it later)
im pretty sure the 512 is encoder lines default setting. which is then editable. i expect only a handful of parameters in that list are important to get right within that file.
but, am i understanding that you think it should still "work", just potentially not work "well"? correct?
thanks.
thanks.
- ihavenofish
9 years 8 months ago #88770
by ihavenofish
alo, thats the spec sheet for the p5 motor. i have nothing for my existing motor, other than resistance which i can measure.
9 years 8 months ago #88777
Indeed. Little to be lost by trying.
ihavenofish wrote: but, am i understanding that you think it should still "work", just potentially not work "well"? correct?
- ihavenofish
9 years 8 months ago #88778
by ihavenofish
sweet, thanks.
lest hope that the auto tuning is smart enough to make it all happy
- ihavenofish
9 years 8 months ago #88793
by ihavenofish
www.sanyodenki.biz/products/INSTRUCTIONM...M0001584J(PY2)-E.pdf
page 279 has the specs for the p5 motor that matches that parameter list.
Time to create page: 0.627 seconds
