Brother TC-225 / TC-229 adventure!
9 years 8 months ago - 9 years 8 months ago #88607 by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
ok, for the tc229, im looking at new delta asd-a2 drives and matching motors - 750w x/y, 1kw z, and then a delta c2000 5.5kw drive to run my spindle. the c2000 is a vfd that can run ac servos with encoders. all of these will take +- 10v input.
i looked at a lot of options for reusing the existing axis servos, but the cost difference to a new delta setup was negligible.
someone i know is using allen bradley ultra 3000 drives with the stock motors, which can be had used fairly cheap, but they seem to have a very slow velocity loop of 300hz (vs 1khz+ for newer systems) which makes me think it wont give good high speed tracking.
anyone have any thoughts on this? ive only ever run step and direction before on comparatively slow machines.
Last edit: 9 years 8 months ago by ihavenofish.
9 years 8 months ago #88641 by ihavenofish
i found some sanyo sanmotion R analogue input drives for $300 us a piece with free shipping. looking at the manual, they should be compatible with the older sanyo motors. i can enter in the correct encoder count. sooo, we'll see early next week. they should arrive tuesday maybe.
if they work, ill order the delta spindle drive and off we go converting to linux :)
9 years 8 months ago #88699 by ihavenofish
hmm. so these drives take a motor profile, which is 53 parameters but they are in hex format.
they have profiles for P5 series motors - 1 model newer than mine (still 90's). in the p5 literature it says p5 is a compatible replacement for mine (65z), and some of the drive instruction manuals meant for the p5 series suggest being compatible with the 65z, though i cant fine motor profile files for them. so i am going to use the motor profile for the p5 model that matches mine. same frame, same speed, same torque.
ill measure the resistance one mine and compare to the p5 specs. if they match, or they are very close, i imagine it should work no?
9 years 8 months ago #88746 by andypugh
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
[quote="ihavenofish" post=88699ill measure the resistance one mine and compare to the p5 specs. if they match, or they are very close, i imagine it should work no?[/quote]
It should be close enough to work at least. I guess very-wrong numbers might lead to problems tuning.
9 years 8 months ago #88749 by ihavenofish
well, its off by a fair bit. the spec of the p5 motor is 1 ohm. my motor is 2 ohms.
i translates the hex to numbers... some of them are obvious, 4 poles, 3600 rpm, most dont correlate to anything on the spec sheet. some are common among many motors. none of them look like they could mean 1 ohm either. why cant they have normal parameters like everyone else? :P
anyhow, i guess we'll just try it and see. the drives are here, i need to wait for a special serial cable first before playing with em.
MOT-TYP,P50B08100H(0100-0290)
COMMENT,200V,30A,ROTARY
MOT-CNT,53
0,0x0004,MOT01 4
1,0x12C9,MOT02 4809
2,0x011E,MOT03 286
3,0x0E10,MOT04 3600
4,0x0000,MOT05 0
5,0x0000,MOT06 0
6,0x07D0,MOT07 2000
7,0x0E10,MOT08 3600
8,0x0000,MOT09 0
9,0x0200,MOT10 512
10,0x0000,MOT11 0
11,0x0000,MOT12 0
12,0x0123,MOT13 291
13,0x0000,MOT14 0
14,0x02E6,MOT15 742
15,0x02E6,MOT16 742
16,0x0831,MOT17 2097
17,0x54A6,MOT18 21670
18,0x0C19,MOT19 3097
19,0x1610,MOT20 5648
20,0x0C91,MOT21 3217
21,0x0340,MOT22 832
22,0x0033,MOT23 51
23,0x01A3,MOT24 419
24,0x003B,MOT25 59
25,0x0082,MOT26 130
26,0xFFE2,MOT27 65506
27,0x02A5,MOT28 677
28,0x005A,MOT29 90
29,0x0000,MOT30
30,0x0000,MOT31
31,0x0000,MOT32
32,0x0000,MOT33
33,0x0000,MOT34
34,0x0000,MOT35
35,0x011E,MOT36 286
36,0x0000,MOT37
37,0x0000,MOT38
38,0x07D0,MOT39 2000
39,0x0E10,MOT40 3600
40,0x0000,MOT41
41,0x0200,MOT42 512
42,0x0000,MOT43
43,0x0000,MOT44
44,0x0123,MOT45 291
45,0x0000,MOT46
46,0x0100,MOT47 256
47,0x0290,MOT48 656
48,0x3550,MOT49 13648
49,0x4230,MOT50 16944
50,0x3830,MOT51 14384
51,0x3031,MOT52 12337
52,0x4830,MOT53 18480
9 years 8 months ago - 9 years 8 months ago #88751 by ihavenofish
machine gets alot smaller with no enclosure :)
The following user(s) said Thank You: arvidb
Time to create page: 2.063 seconds
