Brother TC-225 / TC-229 adventure!
5 years 8 months ago #197938 by ihavenofish
in e stop, enable disappears, and if you wire the motor RST to a contactor it cuts that, and the drive will freewheel. the brake resistors create a "soft" dead short, and the motor will slow down very fast.
the same applies to the X and Y. the Z should have a mechanical brake too, which gets engaged with a relay on e stop.
5 years 8 months ago #198886 by ihavenofish
can someone with a TC225 tell me the model number of the atc brake pack controller? (little box, omron i think).
5 years 8 months ago #200325 by Williamabbe
Hello! I have Brother tc-227 that I’ve been converting. Running dyn4 servos and drives on xyz and also installing a Delta C2000 drive for the original spindle motor. Also running a SZGH 5 axis controller on it. Does anyone have the pin outs on the CN2 20 pin connector that goes from the spindle motor to the main original Sanyo drive? With replacing the old drive I need the encoder pin outs to hook up to the Delta drive with the encoder card. Thanks!
Have a pic of it attached.
5 years 8 months ago #200340 by timfaber
Sorry can't help you out with the pin outs
How are you liking that SZGH controller? Good documentation, post processors, simultaneously control?
5 years 8 months ago #200387 by timfaber
the atc brake pack controller on my tc225 has model number SBR-32 ZP and its by oriental motor
5 years 6 months ago #206947 by timfaber
ihavenofish wrote:
Any change you have your hal and ini files laying around for me? :)
Time to create page: 0.397 seconds
