Brother TC-225 / TC-229 adventure!
5 years 6 months ago #207493 by gcofieldd
Hi Williamabbe,
Take a look at this thread on CNCZone. The individual did a conversion on a TC-225 and used a Delta C2000 with the stock brother spindle motor and it sounds like he had a hell of a time getting it to work.
www.cnczone.com/forums/vertical-mill-lat...-tc225-retrofit.html
5 years 2 months ago #218638 by gcofieldd
@ihavenofish
I was thinking about upgrading the servos on my TC-225 to 750W on X and Y and 1kW on Z. When you were working on both your machines (TC-225 and TC-229) did you notice if the ball screws were the same size? Also, what did you end up doing with the original spindle motor and drive off your TC-229?
5 years 1 month ago #220240 by Superdave
Hello I have a tc 215 I'm trying to retrofit and I was wandering if you have the pin out for the ra12m drives. They still work as do my servos. Can't seem to find info anywhere thanks dave
5 years 3 weeks ago #222476 by IceBear
Hi.
Surely You can retrofit 215 with only 2 mesa cards and few connectors (I did it few times :)
5 years 1 week ago #223594 by ihavenofish
@ihavenofish
hi, missed these posts.
the 2 machines have the same force. 229 has 10 pitch screws and the 225 is 5 pitch. basically the 229 is faster with the same linear force and acceleration ability. 750w are overkill on the 225 in a lot of ways, but that's really all you can buy new for a fair price. 86mm motors cost way more for some reason and used sanyos cost more than new deltas. youll need to make adapters and get new couplings.
i sold both of my machines now. i will eventually buy another, but i think i will try to deliberately find a tc228, which is very similar to the 229, but still has an analogue spindle. replacing the serial spindle drive is just so much money. The guy that bought mine replaced the motor if i recall as it was easier than anything else. my friend is using an AB 3000 drive for his, but its derated to 1kw or so and even then the drive cost like $500-$1000 used.
4 years 10 months ago #229865 by szary11
Gents,
I need some help. For tool change I have to change max limit of Z axis from 0 to 140, perform the toolchange and then switch it back to original one.
I have used ini.z.max_limit and that seems to be set ok, I see the borders of working space reflected on axis visual window and the pin value change on Show HAL Configuration menu.
But still, motion seems to be unaware of limits change, whenever I try to move Z into positive values, it throws me an error "joint position exceeding positive limit".
Although I have not switched kinematics I hoped that maybe forcing synchronization via issues M66 E0 L0 would help, but no luck, still no change.
Any idea on what else might missing?
Time to create page: 0.353 seconds
