Brother TC-225 / TC-229 adventure!
5 years 8 months ago #197905 by Arkadiy
Short 15/16, the green diode on the board lit up and the motor went into hold mode after applying 4 volts to pins 1 and 2. The engine accelerated at a breakneck speed, well it didn't fly away. Thank you for help! The seller sent again from Siberia braking resistors from this servo driver do they need to be connected to the large connectors 1 and 2? And another question for what is the 17 pin in cn2 and where to connect it?
5 years 8 months ago #197913 by ihavenofish
yay. so, single phase works.
my understanding is you need to derate the motor to 2/3 current on single phase.
for the resistors, im not sure where they connect. it will be 2 pins, cause its DC. on my rs1 drives they are labels RB1 and RB2. i guess it cant be that easy eh :)
5 years 8 months ago #197914 by ihavenofish
on the tc229 drives they were lableled COM (dc -/0) and Y.
5 years 8 months ago #197925 by Arkadiy
In the future I will buy a three-phase transformer, now it was only necessary to make sure that the motor was working. Therefore, I will definitely not reduce the power)) the braking resistor is connected to terminals 1 and 2 there are no more places here)) now I will decide how to control my machine, most likely I will choose linuxcnc and mesa board. And what about the 17th pin, what is it responsible for and where do you need to connect it?
5 years 8 months ago #197927 by ihavenofish
its labelled as 24v. so it would connect to your 24v psu...
but i actually don't remember now though with mine. cause all that connector went to the mesa, and, i don't remember connecting anything outside the abz +- / analogue +- / and enable +-
The following user(s) said Thank You: Arkadiy
5 years 8 months ago #197936 by Arkadiy
Okay, but what if the spindle motor stops for some reason? Where to get the emergency stop of the entire system. I suppose that this pin 18 should give an emergency stop? Another thermistor, which must monitor the temperature of the motor and braking resistors, in case of excess temperature, it must open the circuit and stop the machine. Have you worked on this system in your machine?
