Brother TC-225 / TC-229 adventure!
2 years 10 months ago - 2 years 10 months ago #289447 by ihavenofish
I have a manual for the 225 (you can find it on google) but it is not super detailed on electrical. I think that is a separate book I've never found. I t is always worth a try making a polite email to yamazen in the USA. They are quite generous with old manuals and have quite a lot of them in pdf. They sent me the full electrical manuals for my 229.
The conversion is basic though, and most of the info on pinouts is in this thread. I think your PC should be fine. Mine was a core2 duo and it was plenty overkill. You need a PC wit a real PSU is the only hitch I found. My mini lenovo would not power the 5i25.
A warning, you may not get good results form the stock servos. I had a hard time. Other people have had a similar hard time. But a few people have also gotten acceptable results since then, so, it is not an absolute.
Good luck and feel free to ask anything and everything here. There are at least a dozen of us now that poke in here that have worked through most problems.
Last edit: 2 years 10 months ago by ihavenofish.
The following user(s) said Thank You: tommylight, BerTiN
2 years 9 months ago - 2 years 9 months ago #289594 by BerTiN
Thanks a lot for your reply, ihavenofish.
For servos, I sent a mail to a man who managed to use the stock servos, and he said me that there two kinds of driver card for the TC-225. The good one, and the other...
Anyway, I must admit than I would prefer to change them with new ones, and sell them as used OEM parts, which could pay new chinese Delta ones.
I had a look, serveral weeks ago, about the kind of servos I could use, and I found that ones. (pictures)
1kw for Z, and 750w for X and Y. It maybe overkill for this machine, but 400w ones are a bit more expensive.
20 bit absolute encoders, with breaks, pulse-dir command, 220V for each one (I would connect each one on each phase. I've got 380 tri in my barn).
Do you see something wrong with these ones ?
Last edit: 2 years 9 months ago by BerTiN.
2 years 9 months ago #289596 by ihavenofish
I would stick with B3 for all 3 axes for simplicity, but that's the right type of motors. You will need new mounts and couplings.
Interesting about the good vs bad drive versions. Mine was a "first gen" 225. There was a later version than mine with a slightly different casting. Maybe it has a drive update.
2 years 9 months ago - 2 years 9 months ago #289598 by besriworld
If you have three-phase 380-400V. You must connect the drivers in one phase otherwise you will burn the driver.
I shopped at this store a long time ago.You can contact them directly and request a special offer for three sets.
Last edit: 2 years 9 months ago by besriworld.
2 years 9 months ago #289602 by ihavenofish
The brother is 3x200-250. It has a multi tap transformer built in but depending where the machine was "sold" it may ALSO already have a 380=240 step down. If not, you need an external 7-9kva transformer to go from 380 to 240.
The delta drives come in single and 3 phase models. You can technically use either with the right wiring.
2 years 9 months ago #289608 by ihavenofish
Now I'm trying to remember things haha.
380 to neutral is is 220v on a wye transformer. So potentially they are correct using 1 of each line to each drive, although the do not need to do that unless the mains is so weak it unbalances it. 1 hot and 1 neutral would feed all the single phase components. Still in my opinion better to get an external 3 phase transformer though.
#notelectricaladvice :P
besriworld post=289598 userid=22254
Time to create page: 0.321 seconds
