- Thank you received: 6
Noise and vibrations are from interference with unshielde/ungrounded wires, but since it is an old machine, check if motors have brushes and if they do, yank them out and use compressed air inside the brush orifice to remove the fine dust that gathers there and can cause heating during normal work.i tried with a battery and and variable psu but it makes alot of noise and shuts off because of overheating after maybe a minute of running, i guess the drive is overheating since i dont got the tempreature sensor connected.
