Bridgeport Torq-Cut TC4G Retrofit
5 years 7 months ago - 5 years 7 months ago #202641 by chopper79
andypugh wrote: That should work.
One possible issue is that we have had trouble with the docs build inserting dashes "–" in the docs rather than hyphens "-", so perhaps if you copy-pasted that would cause the problem.
Otherwise, I am puzzled.
I was trying to sets spindle-index-enable before net spindle-index-enable <=> hm2_[HOSTMOT2](BOARD).0.encoder.05.index-enable
net spindle-index-enable <=> spindle.0.index-enable
When you mentioned that the signal needs created first is what prompted me to rearrange the position of the sets. Which I then remembered that I have ran into issues in the past when creating my HAL files due to arrangement orders. Once rearranged, it worked fine.
That's what happens when you only get to do this every couple years. I need to do it more often...
Last edit: 5 years 7 months ago by chopper79.
5 years 7 months ago - 5 years 7 months ago #202644 by chopper79
Michael wrote: Mind sharing your hal and ini up to this point? Curious what your tool change looks like.
Clean machine you have there. I am disassembling my enclousre and cleaning/prepping for paint while I wait for my spindle to get back. Mine is pretty beat though.
Well... I got excited and started to go to town on the config and forgot to save a master copy of the working one. Now I am in the process of redoing it as I made a bunch of changes and nothing works right now. I forgot to follow my own rule and that is to save a copy when a milestone is reached so I could always revert back.
I will get it redone this week and post it. Well post the working unfinished config anyway.
Sorry about that!
My toolchange.ngc file is attached though
5 years 7 months ago - 5 years 7 months ago #202646 by chopper79
Michael wrote: I have se questions about your paint choice.
1 Have you used this before?
2 How does it hold up to coolant?
3 Did you use the recommended hardner?
4 Did you go down to bare metal?
5 If not what prep did you do?
6 Cost of the paint and amount used
Thank you
1) Never used this type of paint before. But based on research and recommendation I chose to try it.
2) Not sure, but seems like it will be fine.
3) No hardener (Air dry and is rock hard after a couple days, but could add a hardener)
4) Bare metal where I could which was most of it (This paint is a direct to metal product. does fine on old paint also as long as it is clean and not loose)
5) Cleaned with simple green, then acetone, then sanded, then acetone, then paint. (Not been able to chip it with finger nails and no chips when I dropped a hammer on it. Grease and oil wipe right of with no issue.)
6) $80/gal and I purchased (2) gallon. Wasted 1/2 of first gallon as I did not use if fast enough and the lid was cracked. If everything was prepped then 2-3 gals would do the whole machine easy.
I applied with a brush and a fine roller. I will probably spray the enclosure, but then again may just roll it as the paint levels great.
The following user(s) said Thank You: arvidb, Michael
5 years 7 months ago #202650 by chopper79
Finding the HAL file hard to keep up with. Going to look at doing a component to handle all this stuff. I might call it vmc.comp and it will handle the orientation and transmission/gearbox items. Might even try my hand at adding tool change in it as well. Passing in and out of multiple components is making me crazy. We will see what kind of weird stuff I come up with, if anything...
This will test my lack of C knowledge to the max.
5 years 7 months ago #202668 by andypugh
chopper79 wrote: I was trying to sets spindle-index-enable before net spindle-index-enable <=> hm2_[HOSTMOT2](BOARD).0.encoder.05.index-enable
Right. If a signal does not exist when you get to a "net" command then it is created. But a signal isn't created by a "sets". (though it theory it could be).
You _could_ use
newsig spindle-index-enable sets spindle-index-enable 1 .... net spindle-index-enable...
The following user(s) said Thank You: chopper79
5 years 7 months ago - 5 years 7 months ago #202857 by chopper79
Attached is my current HAL and INI per request.
These are by no means finished so ignore the commented out items or if anything is laid out funny. The config works well excluding orientation which is where everything went bad on me (orientation items are incomplete).
I was going to use the VFD orientation but found that when I switched gears on the transmission the orientation never would line back up at the appropriate angle (No way to know where the gears lined up so no way to use the VFD orientation).
This prompted me to start on the orientation side of things. Using the orient component worked for me but the PID for the orient does not know what to do in low gear vs high gear. The angle always was correct though, but in high gear the spindle would vibrate badly and in low gear it is perfect.
Thought about making it only allow orientation in low gear, but then that causes time and part wear issues. Having to switch to low gear every time I tool changed or oriented the spindle means cycling the valves a lot more. Still working on this part as of now... May be able to do something so that if the spindle is in high gear then divide PID value by transmission ratio. Might have to try it using a scale of some sort.
Time to create page: 0.240 seconds
