Okay i’m feeling quite dumb right now.
I’ve run the Pncconfig wizad and i think it is okay so far. But i get the error message when starting linuxcnc that it can find all the i/os (at least the first one written in the hal, but when outcommented itś just the next that throws the error)
So heres my setup to power the two boards.
7i77 W5 up, W1 right, +11V to the orange field powerblock. Pin 1-4 are +11v and pin 8 is gnd
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/michael/linuxcnc/configs/Maho_MH600E'
Machine configuration file is 'Maho_MH600E.ini'
INIFILE=/home/michael/linuxcnc/configs/Maho_MH600E/Maho_MH600E.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Maho_MH600E.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:05:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:05:00.0
Running HAL shutdown script
Killing task linuxcncsvr, PID=1800
hm2_5i25.0: dropping AnyIO board at 0000:05:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./Maho_MH600E.hal:25: Pin 'hm2_5i25.0.7i77.0.0.output-08' does not exist
1800
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f174250b000
Kernel message information:
[ 0.000000] Linux version 4.9.0-8-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=/dev/sda1 ro quiet
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009dfffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009e00000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b020000-0x000000005be78fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005be79000-0x000000005bfe0fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000005bfe1000-0x000000005c16ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005c170000-0x000000005c57dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000005c57e000-0x000000005d18cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000005d18d000-0x000000005effffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005f000000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021f33ffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 3.2 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. A320M-S2H/A320M-S2H-CF, BIOS F50 11/28/2019
[ 0.000000] Kernel/User page tables isolation: disabled
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x21f340 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF write-through
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFE0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000220000000 aka 8704M
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0x5f000 max_arch_pfn = 0x400000000
[ 0.000000] Base memory trampoline at [ffff99ecc0097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0x489c0000, 0x489c0fff] PGTABLE
[ 0.000000] BRK [0x489c1000, 0x489c1fff] PGTABLE
[ 0.000000] BRK [0x489c2000, 0x489c2fff] PGTABLE
[ 0.000000] BRK [0x489c3000, 0x489c3fff] PGTABLE
[ 0.000000] BRK [0x489c4000, 0x489c4fff] PGTABLE
[ 0.000000] BRK [0x489c5000, 0x489c5fff] PGTABLE
[ 0.000000] BRK [0x489c6000, 0x489c6fff] PGTABLE
[ 0.000000] BRK [0x489c7000, 0x489c7fff] PGTABLE
[ 0.000000] BRK [0x489c8000, 0x489c8fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x35217000-0x36902fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F05A0 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x000000005C4FA0A0 0000BC (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x000000005C500D60 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x000000005C4FA1F0 006B6E (v02 ALASKA A M I 01072009 INTL 20160930)
[ 0.000000] ACPI: FACS 0x000000005C566E00 000040
[ 0.000000] ACPI: APIC 0x000000005C500E78 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x000000005C500FD8 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FIDT 0x000000005C501020 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x000000005C5010C0 000039 (v02 ALASKA A M I 01072009 AMI 01072009)
[ 0.000000] ACPI: SSDT 0x000000005C501100 005419 (v02 ALASKA A M I 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 0x000000005C506520 003699 (v01 ALASKA A M I 00000001 INTL 20160930)
[ 0.000000] ACPI: MCFG 0x000000005C509BC0 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: SSDT 0x000000005C509C00 006810 (v01 ALASKA A M I 00000001 INTL 20160930)
[ 0.000000] ACPI: HPET 0x000000005C510410 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: UEFI 0x000000005C510448 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.000000] ACPI: IVRS 0x000000005C510490 0000D0 (v02 ALASKA A M I 00000001 AMD 00000000)
[ 0.000000] ACPI: CRAT 0x000000005C510560 0002F8 (v01 ALASKA A M I 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 0x000000005C510858 000029 (v01 ALASKA A M I 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x000000005C510888 0012BE (v01 ALASKA A M I 00000001 INTL 20160930)
[ 0.000000] ACPI: SSDT 0x000000005C511B48 00146E (v01 ALASKA A M I 00000001 INTL 20160930)
[ 0.000000] ACPI: SSDT 0x000000005C512FB8 001EC3 (v01 ALASKA A M I 00000001 INTL 20160930)
[ 0.000000] ACPI: SSDT 0x000000005C514E80 0000BF (v01 ALASKA A M I 00001000 INTL 20160930)
[ 0.000000] ACPI: WSMT 0x000000005C514F40 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000021f33ffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x21f33b000-0x21f33ffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000021f33ffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000009dfffff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.000000] node 0: [mem 0x000000000a20b000-0x000000000affffff]
[ 0.000000] node 0: [mem 0x000000000b020000-0x000000005be78fff]
[ 0.000000] node 0: [mem 0x000000005bfe1000-0x000000005c16ffff]
[ 0.000000] node 0: [mem 0x000000005d18d000-0x000000005effffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000021f33ffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021f33ffff]
[ 0.000000] On node 0 totalpages: 1560364
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 5938 pages used for memmap
[ 0.000000] DMA32 zone: 379984 pages, LIFO batch:31
[ 0.000000] Normal zone: 18381 pages used for memmap
[ 0.000000] Normal zone: 1176384 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 3, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 32 CPUs, 31 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x09e00000-0x09ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0a200000-0x0a20afff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x5be79000-0x5bfe0fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x5c170000-0x5c57dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x5c57e000-0x5d18cfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x5f000000-0xdfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[ 0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:32 nr_node_ids:1
[ 0.000000] percpu: Embedded 116 pages/cpu @ffff99eed7800000 s437952 r8192 d28992 u524288
[ 0.000000] pcpu-alloc: s437952 r8192 d28992 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[ 0.000000] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[ 0.000000] pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23
[ 0.000000] pcpu-alloc: [0] 24 25 26 27 [0] 28 29 30 31
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1535960
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=/dev/sda1 ro quiet
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.000000] log_buf_len min size: 131072 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 119668(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 6022272K/6241456K available (6391K kernel code, 1152K rwdata, 2912K rodata, 1680K init, 968K bss, 219184K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=32.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.000000] NR_IRQS:33024 nr_irqs:1224 16
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3493.233 MHz processor
[ 0.000007] Calibrating delay loop (skipped), value calculated using timer frequency.. 6986.46 BogoMIPS (lpj=13972932)
[ 0.000007] pid_max: default: 32768 minimum: 301
[ 0.000024] ACPI: Core revision 20160831
[ 0.007480] ACPI: 9 ACPI AML tables successfully acquired and loaded
[ 0.007536] Security Framework initialized
[ 0.007537] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.007540] AppArmor: AppArmor disabled by boot time parameter
[ 0.008158] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.010865] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.011548] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.011554] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.011859] mce: CPU supports 23 MCE banks
[ 0.011874] LVT offset 1 assigned for vector 0xf9
[ 0.011927] LVT offset 2 assigned for vector 0xf4
[ 0.011937] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.011938] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[ 0.011939] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.011939] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.011940] Spectre V2 : Spectre v2 mitigation: Enabling Indirect Branch Prediction Barrier
[ 0.011940] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.015538] ftrace: allocating 25230 entries in 99 pages
[ 0.029677] smpboot: Max logical packages: 32
[ 0.613842] Switched APIC routing to physical flat.
[ 0.615298] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.762549] smpboot: CPU0: AMD Athlon 3000G with Radeon Vega Graphics (family: 0x17, model: 0x18, stepping: 0x1)
[ 0.762554] Performance Events: Fam17h core perfctr, AMD PMU driver.
[ 0.762559] ... version: 0
[ 0.762559] ... bit width: 48
[ 0.762560] ... generic registers: 6
[ 0.762560] ... value mask: 0000ffffffffffff
[ 0.762561] ... max period: 00007fffffffffff
[ 0.762561] ... fixed-purpose events: 0
[ 0.762562] ... event mask: 000000000000003f
[ 0.818870] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.826556] x86: Booted up 1 node, 1 CPUs
[ 0.826559] smpboot: Total of 1 processors activated (6986.46 BogoMIPS)
[ 0.827778] devtmpfs: initialized
[ 0.827858] x86/mm: Memory block size: 128MB
[ 0.830580] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20afff] (45056 bytes)
[ 0.830581] PM: Registering ACPI NVS region [mem 0x5c170000-0x5c57dfff] (4251648 bytes)
[ 0.830705] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.830780] futex hash table entries: 8192 (order: 8, 1048576 bytes)
[ 0.831048] pinctrl core: initialized pinctrl subsystem
[ 0.831242] NET: Registered protocol family 16
[ 0.834579] cpuidle: using governor ladder
[ 0.834591] cpuidle: using governor menu
[ 0.834780] ACPI: bus type PCI registered
[ 0.834782] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.834910] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.834912] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.834924] PCI: Using configuration type 1 for base access
[ 0.838634] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.838636] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.854673] ACPI: Added _OSI(Module Device)
[ 0.854675] ACPI: Added _OSI(Processor Device)
[ 0.854676] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.854677] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.854975] ACPI: Executed 7 blocks of module-level executable AML code
[ 0.859870] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.864779] ACPI: Interpreter enabled
[ 0.864790] ACPI: (supports S0 S4 S5)
[ 0.864791] ACPI: Using IOAPIC for interrupt routing
[ 0.865129] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.865471] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 0.866071] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 0.870600] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.870604] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.870772] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.870781] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.871018] PCI host bridge to bus 0000:00
[ 0.871020] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.871021] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.871022] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.871023] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.871024] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.871025] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.871026] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window]
[ 0.871027] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.871028] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.871037] pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
[ 0.871150] pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
[ 0.871296] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.871398] pci 0000:00:01.2: [1022:15d3] type 01 class 0x060400
[ 0.871480] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.871534] pci 0000:00:01.2: System wakeup disabled by ACPI
[ 0.871589] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.871693] pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
[ 0.871781] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.871830] pci 0000:00:08.1: System wakeup disabled by ACPI
[ 0.871863] pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400
[ 0.871951] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.871999] pci 0000:00:08.2: System wakeup disabled by ACPI
[ 0.872065] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.872270] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.872439] pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
[ 0.872485] pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
[ 0.872531] pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
[ 0.872576] pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
[ 0.872625] pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
[ 0.872671] pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
[ 0.872717] pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
[ 0.872765] pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
[ 0.872898] pci 0000:01:00.0: [1022:43bc] type 00 class 0x0c0330
[ 0.872920] pci 0000:01:00.0: reg 0x10: [mem 0xfcea0000-0xfcea7fff 64bit]
[ 0.873030] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.873081] pci 0000:01:00.0: System wakeup disabled by ACPI
[ 0.873115] pci 0000:01:00.1: [1022:43b8] type 00 class 0x010601
[ 0.873175] pci 0000:01:00.1: reg 0x24: [mem 0xfce80000-0xfce9ffff]
[ 0.873185] pci 0000:01:00.1: reg 0x30: [mem 0xfce00000-0xfce7ffff pref]
[ 0.873234] pci 0000:01:00.1: PME# supported from D3hot D3cold
[ 0.873297] pci 0000:01:00.2: [1022:43b3] type 01 class 0x060400
[ 0.873390] pci 0000:01:00.2: PME# supported from D3hot D3cold
[ 0.882582] pci 0000:00:01.2: PCI bridge to [bus 01-07]
[ 0.882590] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.882595] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.882603] pci 0000:00:01.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.882782] pci 0000:02:04.0: [1022:43b4] type 01 class 0x060400
[ 0.882923] pci 0000:02:04.0: PME# supported from D3hot D3cold
[ 0.883064] pci 0000:02:05.0: [1022:43b4] type 01 class 0x060400
[ 0.883198] pci 0000:02:05.0: PME# supported from D3hot D3cold
[ 0.883323] pci 0000:02:06.0: [1022:43b4] type 01 class 0x060400
[ 0.883454] pci 0000:02:06.0: PME# supported from D3hot D3cold
[ 0.883560] pci 0000:02:07.0: [1022:43b4] type 01 class 0x060400
[ 0.883686] pci 0000:02:07.0: PME# supported from D3hot D3cold
[ 0.883808] pci 0000:01:00.2: PCI bridge to [bus 02-07]
[ 0.883815] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.883820] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcdfffff]
[ 0.883827] pci 0000:01:00.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.883887] pci 0000:02:04.0: PCI bridge to [bus 03]
[ 0.883985] pci 0000:04:00.0: [1b21:1080] type 01 class 0x060400
[ 0.884196] pci 0000:04:00.0: supports D1 D2
[ 0.884198] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.894577] pci 0000:02:05.0: PCI bridge to [bus 04-05]
[ 0.894588] pci 0000:02:05.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.894689] pci 0000:05:00.0: [2718:5125] type 00 class 0x110000
[ 0.894721] pci 0000:05:00.0: reg 0x10: [mem 0xfcd00000-0xfcd0ffff]
[ 0.894997] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.895014] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.895094] pci 0000:02:06.0: PCI bridge to [bus 06]
[ 0.895190] pci 0000:07:00.0: [10ec:8168] type 00 class 0x020000
[ 0.895222] pci 0000:07:00.0: reg 0x10: [io 0xf000-0xf0ff]
[ 0.895269] pci 0000:07:00.0: reg 0x18: [mem 0xfcc00000-0xfcc00fff 64bit]
[ 0.895298] pci 0000:07:00.0: reg 0x20: [mem 0xf0300000-0xf0303fff 64bit pref]
[ 0.895461] pci 0000:07:00.0: supports D1 D2
[ 0.895462] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.906583] pci 0000:02:07.0: PCI bridge to [bus 07]
[ 0.906590] pci 0000:02:07.0: bridge window [io 0xf000-0xffff]
[ 0.906594] pci 0000:02:07.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.906602] pci 0000:02:07.0: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.906767] pci 0000:08:00.0: [1002:15d8] type 00 class 0x030000
[ 0.906797] pci 0000:08:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.906818] pci 0000:08:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.906832] pci 0000:08:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.906846] pci 0000:08:00.0: reg 0x24: [mem 0xfcb00000-0xfcb7ffff]
[ 0.906974] pci 0000:08:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.907107] pci 0000:08:00.1: [1002:15de] type 00 class 0x040300
[ 0.907129] pci 0000:08:00.1: reg 0x10: [mem 0xfcb88000-0xfcb8bfff]
[ 0.907280] pci 0000:08:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.907369] pci 0000:08:00.2: [1022:15df] type 00 class 0x108000
[ 0.907416] pci 0000:08:00.2: reg 0x18: [mem 0xfca00000-0xfcafffff]
[ 0.907454] pci 0000:08:00.2: reg 0x24: [mem 0xfcb8c000-0xfcb8dfff]
[ 0.907635] pci 0000:08:00.3: [1022:15e5] type 00 class 0x0c0330
[ 0.907665] pci 0000:08:00.3: reg 0x10: [mem 0xfc900000-0xfc9fffff 64bit]
[ 0.907812] pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
[ 0.907852] pci 0000:08:00.3: System wakeup disabled by ACPI
[ 0.907908] pci 0000:08:00.6: [1022:15e3] type 00 class 0x040300
[ 0.907930] pci 0000:08:00.6: reg 0x10: [mem 0xfcb80000-0xfcb87fff]
[ 0.908082] pci 0000:08:00.6: PME# supported from D0 D3hot D3cold
[ 0.908204] pci 0000:00:08.1: PCI bridge to [bus 08]
[ 0.908210] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.908214] pci 0000:00:08.1: bridge window [mem 0xfc900000-0xfcbfffff]
[ 0.908221] pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.908324] pci 0000:09:00.0: [1022:7901] type 00 class 0x010601
[ 0.908408] pci 0000:09:00.0: reg 0x24: [mem 0xfcf00000-0xfcf007ff]
[ 0.908508] pci 0000:09:00.0: PME# supported from D3hot D3cold
[ 0.908610] pci 0000:00:08.2: PCI bridge to [bus 09]
[ 0.908620] pci 0000:00:08.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.909066] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909120] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909166] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909225] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909276] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909318] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909360] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.909402] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.910022] vgaarb: setting as boot device: PCI:0000:08:00.0
[ 0.910023] vgaarb: device added: PCI:0000:08:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.910024] vgaarb: loaded
[ 0.910025] vgaarb: bridge control possible 0000:08:00.0
[ 0.910575] PCI: Using ACPI for IRQ routing
[ 0.913538] PCI: pci_cache_line_size set to 64 bytes
[ 0.913637] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.913639] e820: reserve RAM buffer [mem 0x0009d400-0x0009ffff]
[ 0.913640] e820: reserve RAM buffer [mem 0x09e00000-0x0bffffff]
[ 0.913641] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.913642] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.913642] e820: reserve RAM buffer [mem 0x5be79000-0x5bffffff]
[ 0.913643] e820: reserve RAM buffer [mem 0x5c170000-0x5fffffff]
[ 0.913644] e820: reserve RAM buffer [mem 0x5f000000-0x5fffffff]
[ 0.913645] e820: reserve RAM buffer [mem 0x21f340000-0x21fffffff]
[ 0.913782] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.913785] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.916831] clocksource: Switched to clocksource hpet
[ 0.923796] VFS: Disk quotas dquot_6.6.0
[ 0.923823] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.923915] pnp: PnP ACPI init
[ 0.924034] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.924037] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.924091] system 00:01: [mem 0x60000000-0xdfffffff window] has been reserved
[ 0.924093] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.924222] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.924343] system 00:03: [io 0x0a00-0x0a2f] has been reserved
[ 0.924344] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 0.924345] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 0.924347] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.924384] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.924427] pnp 00:05: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.924588] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.924589] system 00:06: [io 0x040b] has been reserved
[ 0.924590] system 00:06: [io 0x04d6] has been reserved
[ 0.924592] system 00:06: [io 0x0c00-0x0c01] has been reserved
[ 0.924593] system 00:06: [io 0x0c14] has been reserved
[ 0.924594] system 00:06: [io 0x0c50-0x0c51] has been reserved
[ 0.924595] system 00:06: [io 0x0c52] has been reserved
[ 0.924596] system 00:06: [io 0x0c6c] has been reserved
[ 0.924597] system 00:06: [io 0x0c6f] has been reserved
[ 0.924598] system 00:06: [io 0x0cd0-0x0cd1] has been reserved
[ 0.924599] system 00:06: [io 0x0cd2-0x0cd3] has been reserved
[ 0.924600] system 00:06: [io 0x0cd4-0x0cd5] has been reserved
[ 0.924601] system 00:06: [io 0x0cd6-0x0cd7] has been reserved
[ 0.924602] system 00:06: [io 0x0cd8-0x0cdf] has been reserved
[ 0.924607] system 00:06: [io 0x0800-0x089f] has been reserved
[ 0.924608] system 00:06: [io 0x0b00-0x0b0f] has been reserved
[ 0.924609] system 00:06: [io 0x0b20-0x0b3f] has been reserved
[ 0.924610] system 00:06: [io 0x0900-0x090f] has been reserved
[ 0.924611] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.924613] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.924614] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.924615] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.924616] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.924618] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.924619] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.924620] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.924622] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.925010] pnp: PnP ACPI: found 7 devices
[ 0.930613] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.930720] pci 0000:02:04.0: PCI bridge to [bus 03]
[ 0.930736] pci 0000:04:00.0: PCI bridge to [bus 05]
[ 0.930745] pci 0000:04:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.930763] pci 0000:02:05.0: PCI bridge to [bus 04-05]
[ 0.930768] pci 0000:02:05.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.930778] pci 0000:02:06.0: PCI bridge to [bus 06]
[ 0.930792] pci 0000:02:07.0: PCI bridge to [bus 07]
[ 0.930794] pci 0000:02:07.0: bridge window [io 0xf000-0xffff]
[ 0.930800] pci 0000:02:07.0: bridge window [mem 0xfcc00000-0xfccfffff]
[ 0.930804] pci 0000:02:07.0: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930811] pci 0000:01:00.2: PCI bridge to [bus 02-07]
[ 0.930813] pci 0000:01:00.2: bridge window [io 0xf000-0xffff]
[ 0.930818] pci 0000:01:00.2: bridge window [mem 0xfcc00000-0xfcdfffff]
[ 0.930822] pci 0000:01:00.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930828] pci 0000:00:01.2: PCI bridge to [bus 01-07]
[ 0.930830] pci 0000:00:01.2: bridge window [io 0xf000-0xffff]
[ 0.930835] pci 0000:00:01.2: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.930839] pci 0000:00:01.2: bridge window [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930846] pci 0000:00:08.1: PCI bridge to [bus 08]
[ 0.930849] pci 0000:00:08.1: bridge window [io 0xe000-0xefff]
[ 0.930854] pci 0000:00:08.1: bridge window [mem 0xfc900000-0xfcbfffff]
[ 0.930857] pci 0000:00:08.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.930865] pci 0000:00:08.2: PCI bridge to [bus 09]
[ 0.930870] pci 0000:00:08.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.930880] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.930882] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.930883] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.930883] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.930884] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.930885] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.930887] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec2ffff window]
[ 0.930887] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[ 0.930889] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 0.930890] pci_bus 0000:01: resource 1 [mem 0xfcc00000-0xfcefffff]
[ 0.930890] pci_bus 0000:01: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930892] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.930893] pci_bus 0000:02: resource 1 [mem 0xfcc00000-0xfcdfffff]
[ 0.930894] pci_bus 0000:02: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930895] pci_bus 0000:04: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.930896] pci_bus 0000:05: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.930897] pci_bus 0000:07: resource 0 [io 0xf000-0xffff]
[ 0.930898] pci_bus 0000:07: resource 1 [mem 0xfcc00000-0xfccfffff]
[ 0.930899] pci_bus 0000:07: resource 2 [mem 0xf0300000-0xf03fffff 64bit pref]
[ 0.930900] pci_bus 0000:08: resource 0 [io 0xe000-0xefff]
[ 0.930901] pci_bus 0000:08: resource 1 [mem 0xfc900000-0xfcbfffff]
[ 0.930902] pci_bus 0000:08: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.930903] pci_bus 0000:09: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 0.930994] NET: Registered protocol family 2
[ 0.931272] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.931618] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.932101] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.932156] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.932250] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.932420] NET: Registered protocol family 1
[ 0.932636] pci 0000:08:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.932824] PCI: CLS 64 bytes, default 64
[ 0.932906] Unpacking initramfs...
[ 1.214450] Freeing initrd memory: 23472K
[ 1.214480] AMD-Vi: Unable to write to IOMMU perf counter.
[ 1.214749] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 1.214750] pci 0000:00:00.2: PCI INT A: not connected
[ 1.215142] iommu: Adding device 0000:00:01.0 to group 0
[ 1.215169] iommu: Adding device 0000:00:01.2 to group 0
[ 1.215353] iommu: Adding device 0000:00:08.0 to group 1
[ 1.215378] iommu: Adding device 0000:00:08.1 to group 1
[ 1.215401] iommu: Adding device 0000:00:08.2 to group 1
[ 1.215577] iommu: Adding device 0000:00:14.0 to group 2
[ 1.215596] iommu: Adding device 0000:00:14.3 to group 2
[ 1.215811] iommu: Adding device 0000:00:18.0 to group 3
[ 1.215830] iommu: Adding device 0000:00:18.1 to group 3
[ 1.215849] iommu: Adding device 0000:00:18.2 to group 3
[ 1.215868] iommu: Adding device 0000:00:18.3 to group 3
[ 1.215889] iommu: Adding device 0000:00:18.4 to group 3
[ 1.215908] iommu: Adding device 0000:00:18.5 to group 3
[ 1.215927] iommu: Adding device 0000:00:18.6 to group 3
[ 1.215945] iommu: Adding device 0000:00:18.7 to group 3
[ 1.215968] iommu: Adding device 0000:01:00.0 to group 0
[ 1.215986] iommu: Adding device 0000:01:00.1 to group 0
[ 1.216004] iommu: Adding device 0000:01:00.2 to group 0
[ 1.216024] iommu: Adding device 0000:02:04.0 to group 0
[ 1.216045] iommu: Adding device 0000:02:05.0 to group 0
[ 1.216065] iommu: Adding device 0000:02:06.0 to group 0
[ 1.216084] iommu: Adding device 0000:02:07.0 to group 0
[ 1.216104] iommu: Adding device 0000:04:00.0 to group 0
[ 1.216119] iommu: Adding device 0000:05:00.0 to group 0
[ 1.216146] iommu: Adding device 0000:07:00.0 to group 0
[ 1.216213] iommu: Adding device 0000:08:00.0 to group 1
[ 1.216244] iommu: Adding device 0000:08:00.1 to group 1
[ 1.216275] iommu: Adding device 0000:08:00.2 to group 1
[ 1.216308] iommu: Adding device 0000:08:00.3 to group 1
[ 1.216339] iommu: Adding device 0000:08:00.6 to group 1
[ 1.216372] iommu: Adding device 0000:09:00.0 to group 1
[ 1.216688] AMD-Vi: Found IOMMU at 0000:00:00.2 cap 0x40
[ 1.216688] AMD-Vi: Extended features (0x4f77ef22294ada):
[ 1.216689] PPR NX GT IA GA PC GA_vAPIC
[ 1.216691] AMD-Vi: Interrupt remapping enabled
[ 1.216692] AMD-Vi: virtual APIC enabled
[ 1.216928] AMD-Vi: Lazy IO/TLB flushing enabled
[ 1.219791] perf: AMD NB counters detected
[ 1.219805] perf: AMD L2I counters detected
[ 1.220314] audit: initializing netlink subsys (disabled)
[ 1.220327] audit: type=2000 audit(1592864973.536:1): initialized
[ 1.224959] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 1.226287] zbud: loaded
[ 1.227133] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.231198] io scheduler noop registered
[ 1.231199] io scheduler deadline registered
[ 1.231225] io scheduler cfq registered (default)
[ 1.232528] pcieport 0000:00:01.2: Signaling PME through PCIe PME interrupt
[ 1.232529] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.232530] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 1.232531] pcieport 0000:01:00.2: Signaling PME through PCIe PME interrupt
[ 1.232532] pcieport 0000:02:04.0: Signaling PME through PCIe PME interrupt
[ 1.232533] pcieport 0000:02:05.0: Signaling PME through PCIe PME interrupt
[ 1.232534] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 1.232535] pci 0000:05:00.0: Signaling PME through PCIe PME interrupt
[ 1.232536] pcieport 0000:02:06.0: Signaling PME through PCIe PME interrupt
[ 1.232537] pcieport 0000:02:07.0: Signaling PME through PCIe PME interrupt
[ 1.232538] pci 0000:07:00.0: Signaling PME through PCIe PME interrupt
[ 1.232541] pcie_pme 0000:00:01.2:pcie001: service driver pcie_pme loaded
[ 1.232593] pcieport 0000:00:08.1: Signaling PME through PCIe PME interrupt
[ 1.232595] pci 0000:08:00.0: Signaling PME through PCIe PME interrupt
[ 1.232596] pci 0000:08:00.1: Signaling PME through PCIe PME interrupt
[ 1.232597] pci 0000:08:00.2: Signaling PME through PCIe PME interrupt
[ 1.232598] pci 0000:08:00.3: Signaling PME through PCIe PME interrupt
[ 1.232599] pci 0000:08:00.6: Signaling PME through PCIe PME interrupt
[ 1.232603] pcie_pme 0000:00:08.1:pcie001: service driver pcie_pme loaded
[ 1.232651] pcieport 0000:00:08.2: Signaling PME through PCIe PME interrupt
[ 1.232652] pci 0000:09:00.0: Signaling PME through PCIe PME interrupt
[ 1.232656] pcie_pme 0000:00:08.2:pcie001: service driver pcie_pme loaded
[ 1.232664] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.232668] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.232801] GHES: HEST is not enabled!
[ 1.232877] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.233234] Linux agpgart interface v0.103
[ 1.233312] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.237579] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.238331] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.238335] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.238438] mousedev: PS/2 mouse device common for all mice
[ 1.238477] rtc_cmos 00:02: RTC can wake from S4
[ 1.238658] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.238750] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.239116] NET: Registered protocol family 10
[ 1.243458] mip6: Mobile IPv6
[ 1.243460] NET: Registered protocol family 17
[ 1.243461] mpls_gso: MPLS GSO support
[ 1.243624] microcode: CPU0: patch_level=0x08108109
[ 1.243645] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.243732] registered taskstats version 1
[ 1.243746] zswap: loaded using pool lzo/zbud
[ 1.243779] ima: No TPM chip found, activating TPM-bypass!
[ 1.243780] ima: Allocated hash algorithm: sha256
[ 1.244309] rtc_cmos 00:02: setting system clock to 2020-06-22 22:29:34 UTC (1592864974)
[ 1.244357] PM: Hibernation image not present or could not be loaded.
[ 1.245574] Freeing unused kernel memory: 1680K
[ 1.245575] Write protecting the kernel read-only data: 12288k
[ 1.246043] Freeing unused kernel memory: 1784K
[ 1.247873] Freeing unused kernel memory: 1184K
[ 1.251802] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.261498] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.261525] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.263386] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.318046] ACPI: bus type USB registered
[ 1.318064] usbcore: registered new interface driver usbfs
[ 1.318070] usbcore: registered new interface driver hub
[ 1.318100] usbcore: registered new device driver usb
[ 1.318931] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.318935] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.321078] SCSI subsystem initialized
[ 1.322982] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20160831/utaddress-247)
[ 1.322988] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 1.327057] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.334104] libata version 3.00 loaded.
[ 1.337879] r8169 0000:07:00.0 eth0: RTL8168g/8111g at 0xffffb672c1499000, 18:c0:4d:21:64:1e, XID 0c000800 IRQ 38
[ 1.337880] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.350092] AVX2 version of gcm_enc/dec engaged.
[ 1.350093] AES CTR mode by8 optimization enabled
[ 1.378213] xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x00000410
[ 1.382618] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.382620] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.382621] usb usb1: Product: xHCI Host Controller
[ 1.382622] usb usb1: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 1.382623] usb usb1: SerialNumber: 0000:01:00.0
[ 1.382732] hub 1-0:1.0: USB hub found
[ 1.382747] hub 1-0:1.0: 9 ports detected
[ 1.383010] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.383012] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.383014] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.383060] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.383076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.383077] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.383113] usb usb2: Product: xHCI Host Controller
[ 1.383114] usb usb2: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 1.383115] usb usb2: SerialNumber: 0000:01:00.0
[ 1.383193] hub 2-0:1.0: USB hub found
[ 1.383201] hub 2-0:1.0: 3 ports detected
[ 1.383321] ahci 0000:01:00.1: version 3.0
[ 1.383462] ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
[ 1.383512] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0x33 impl SATA mode
[ 1.383514] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 1.383720] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 1.383723] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 3
[ 1.384060] xhci_hcd 0000:08:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x00000410
[ 1.386387] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.386388] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.386389] usb usb3: Product: xHCI Host Controller
[ 1.386390] usb usb3: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 1.386391] usb usb3: SerialNumber: 0000:08:00.3
[ 1.386472] hub 3-0:1.0: USB hub found
[ 1.386491] hub 3-0:1.0: 6 ports detected
[ 1.387179] xhci_hcd 0000:08:00.3: xHCI Host Controller
[ 1.387182] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 4
[ 1.387183] xhci_hcd 0000:08:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.387240] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.387258] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.387259] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.387260] usb usb4: Product: xHCI Host Controller
[ 1.387260] usb usb4: Manufacturer: Linux 4.9.0-8-rt-amd64 xhci-hcd
[ 1.387261] usb usb4: SerialNumber: 0000:08:00.3
[ 1.387340] hub 4-0:1.0: USB hub found
[ 1.387354] hub 4-0:1.0: 4 ports detected
[ 1.394405] scsi host0: ahci
[ 1.398624] scsi host1: ahci
[ 1.402817] scsi host2: ahci
[ 1.407039] scsi host3: ahci
[ 1.411260] scsi host4: ahci
[ 1.415615] scsi host5: ahci
[ 1.419971] scsi host6: ahci
[ 1.424337] scsi host7: ahci
[ 1.424388] ata1: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80100 irq 41
[ 1.424390] ata2: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80180 irq 41
[ 1.424391] ata3: DUMMY
[ 1.424392] ata4: DUMMY
[ 1.424394] ata5: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80300 irq 41
[ 1.424396] ata6: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80380 irq 41
[ 1.424397] ata7: DUMMY
[ 1.424398] ata8: DUMMY
[ 1.434852] ahci 0000:09:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 1.434855] ahci 0000:09:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 1.439300] scsi host8: ahci
[ 1.439358] ata9: SATA max UDMA/133 abar m2048@0xfcf00000 port 0xfcf00100 irq 46
[ 1.739638] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.768907] usb 1-4: new high-speed USB device number 2 using xhci_hcd
[ 1.771678] ata9: SATA link down (SStatus 0 SControl 300)
[ 1.989631] usb 1-4: New USB device found, idVendor=0bda, idProduct=8178
[ 1.989633] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.989634] usb 1-4: Product: 802.11n WLAN Adapter
[ 1.989635] usb 1-4: Manufacturer: Realtek
[ 1.989637] usb 1-4: SerialNumber: 00e04c000001
[ 2.051551] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.172936] usb 1-5: new full-speed USB device number 3 using xhci_hcd
[ 2.248943] tsc: Refined TSC clocksource calibration: 3493.451 MHz
[ 2.248947] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x325b269fa36, max_idle_ns: 440795269021 ns
[ 2.363622] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.564469] usb 1-5: New USB device found, idVendor=046d, idProduct=c534
[ 2.564472] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.564474] usb 1-5: Product: USB Receiver
[ 2.564476] usb 1-5: Manufacturer: Logitech
[ 2.574546] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.614512] usbcore: registered new interface driver usbhid
[ 2.614514] usbhid: USB HID core driver
[ 2.615503] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-5/1-5:1.0/0003:046D:C534.0001/input/input3
[ 2.673567] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-5/input0
[ 2.673807] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-5/1-5:1.1/0003:046D:C534.0002/input/input4
[ 2.733149] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-5/input1
[ 2.836985] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.838264] ata6.00: ATA-11: WDC WDS250G2B0A-00SM50, 401020WD, max UDMA/133
[ 2.838267] ata6.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 2.840541] ata6.00: configured for UDMA/133
[ 2.844851] scsi 5:0:0:0: Direct-Access ATA WDC WDS250G2B0A 20WD PQ: 0 ANSI: 5
[ 2.869939] sd 5:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 2.870011] sd 5:0:0:0: [sda] Write Protect is off
[ 2.870013] sd 5:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.870033] sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.870538] sda: sda1 sda2 < sda5 >
[ 2.870880] sd 5:0:0:0: [sda] Attached SCSI disk
[ 3.273053] clocksource: Switched to clocksource tsc
[ 3.337859] ACPI: Invalid passive threshold
[ 3.338285] thermal LNXTHERM:00: registered as thermal_zone0
[ 3.338286] ACPI: Thermal Zone [TZ10] (17 C)
[ 3.352054] PM: Starting manual resume from disk
[ 3.352057] PM: Hibernation image partition 8:5 present
[ 3.352057] PM: Looking for hibernation image.
[ 3.352185] PM: Image not found (code -22)
[ 3.352186] PM: Hibernation image not present or could not be loaded.
[ 3.392231] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.392698] random: fast init done
[ 3.467791] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.474673] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.474754] systemd[1]: Detected architecture x86-64.
[ 3.474883] systemd[1]: Set hostname to <LinuxCNC>.
[ 3.522984] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 3.522998] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 3.523320] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.523411] systemd[1]: Listening on Journal Audit Socket.
[ 3.523534] systemd[1]: Created slice System Slice.
[ 3.523564] systemd[1]: Listening on Syslog Socket.
[ 3.523584] systemd[1]: Listening on udev Kernel Socket.
[ 3.557757] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 3.561274] lp: driver loaded but no devices found
[ 3.569237] ppdev: user-space parallel port driver
[ 3.746887] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[ 3.746891] ACPI: Power Button [PWRB]
[ 3.746938] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 3.746940] ACPI: Power Button [PWRF]
[ 3.768836] ACPI: Video Device [VGA1] (multi-head: yes rom: no post: no)
[ 3.768874] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 3.769150] acpi device:10: registered as cooling_device1
[ 3.769190] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/LNXVIDEO:01/input/input7
[ 3.784691] systemd-journald[220]: Received request to flush runtime journal from PID 1
[ 3.823075] wmi: Mapper loaded
[ 3.828801] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.859854] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 3.936284] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[ 3.936334] sp5100_tco: PCI Vendor ID: 0x1022, Device ID: 0x790b, Revision ID: 0x61
[ 3.936393] sp5100_tco: failed to find MMIO address, giving up.
[ 3.937618] snd_hda_intel 0000:08:00.1: Handle vga_switcheroo audio client
[ 3.968456] Adding 6240252k swap on /dev/sda5. Priority:-1 extents:1 across:6240252k SSFS
[ 3.975197] input: PC Speaker as /devices/platform/pcspkr/input/input8
[ 4.001071] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card0/input9
[ 4.001119] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card0/input10
[ 4.001158] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card0/input11
[ 4.007926] rtl8192cu: Chip version 0x11
[ 4.058221] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 4.058224] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.058225] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 4.058226] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 4.058227] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x11/0x0
[ 4.058227] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 4.058229] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 4.058230] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 4.058231] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 4.130193] kvm: disabled by bios
[ 4.331880] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1/input12
[ 4.333389] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1/input13
[ 4.333523] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1/input14
[ 4.335452] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1/input15
[ 4.335586] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card1/input16
[ 4.484400] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[ 4.559292] r8169 0000:07:00.0 eth0: link down
[ 4.559386] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.216972] rtl8192cu: Board Type 0
[ 7.225968] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 7.226014] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 7.231051] usb 1-4: firmware: direct-loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 7.234392] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 7.234590] usbcore: registered new interface driver rtl8192cu
[ 7.257991] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.280976] rtl8192cu: MAC auto ON okay!
[ 8.871086] rtl8192cu: Tx queue select: 0x05
[ 24.467235] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.664187] rtl8192cu: MAC auto ON okay!
[ 26.254299] rtl8192cu: Tx queue select: 0x05
[ 41.718406] random: crng init done
[ 41.718407] random: 7 urandom warning(s) missed due to ratelimiting
[ 41.877449] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 41.934267] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 113.697399] rtl8192cu: MAC auto ON okay!
[ 115.287508] rtl8192cu: Tx queue select: 0x05
[ 130.886731] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 133.616870] wlan0: authenticate with 90:5c:44:c6:03:e6
[ 134.000840] wlan0: send auth to 90:5c:44:c6:03:e6 (try 1/3)
[ 134.003343] wlan0: authenticated
[ 134.004907] wlan0: associating with AP with corrupt probe response
[ 134.005189] wlan0: associate with 90:5c:44:c6:03:e6 (try 1/3)
[ 134.045595] wlan0: RX AssocResp from 90:5c:44:c6:03:e6 (capab=0x431 status=0 aid=1)
[ 134.188846] wlan0: associated
[ 134.769915] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
TASK=milltask
HALUI=halui
DISPLAY=axis
hm2: unloading
1800
