- Thank you received: 4
| 7i77 | EXE |
| QA0 | Ua1 |
| /QA0 | /Ua1 |
| GND | 0V |
| QB0 | Ua2 |
| /QB0 | Ua2 |
| +5V | +5V |
| IDX0 | ??? |
| /IDX0 | ??? |
I really wish you would stop doing that, almost had a heart attack reading thisOnkelmat wrote: .......... I then added my lab power supply to power the 7i77 5v into TB1. Jumpers are set to seperate vin and vfield.
Can you turn the motor by hand?Onkelmat wrote: Any advice on tuning the axis with belt driven ballscrews ? Pncconig wizard wants to know thread pitch and gearratio etc. how to ?
In the 7i77 manual it clearly states:
Set the 5i25/6i25 to power the 7i77 logic side with the respective jumpers on the 5i25/6i25 and 7i77
OR
again
OR
set the 5i25/6i25 to NOT power the 7i77 and power the 7i77 by supplying 5V to TB1
NEVER power the TB1 while you have the 7i77 set to get power from 5i25/6i25 and the 5i25/6i25 is set to deliver power to the 7i77.
The way you have it, you are back powering the whole 5V rail on the PC and everything in between.
5V on the TB1 has nothing to do with the Vin and Vfield and how they are set.
The crashing PC might be due to to much power draw from the 5V rail on the PC through 5i25/6i25 and 7i77 by the encoders, so change the jumpers on the 5i25/6i25 and 7i77 to have separate 5V on the 7i77, then add another 5V 2A power supply to TB1 on the 7i77.
tommylight wrote: Also, do NOT do anything without wiring the drive enable to 7i77 as it is not clear from you post if you already have that working.
That is a must, not an option, as any error or runaway will be immediately stopped by linuxcnc.
Oh good. Me very glad !Onkelmat wrote: I set the jumpers as following BEFORE powering TB1 with a separate power supply
