Retrofitting Maho MH600E 1989 - Meas 5i25 & 7i77
6 years 3 months ago - 6 years 3 months ago #173897 by Onkelmat
RotarySMP wrote: I just resent the manual, and also a separate test email.
seems like the temporary mail service is not reliable.
I´ll remove this adress later.
EDIT: removed my E-Mail
Last edit: 6 years 3 months ago by Onkelmat.
6 years 3 months ago #173899 by RotarySMP
I just sent them. You can delete that now.
The following user(s) said Thank You: Onkelmat
6 years 3 months ago #173954 by Onkelmat
got it on the tmper mail now :D
6 years 3 months ago #173962 by RotarySMP
Hope that it helps.
6 years 3 months ago #174057 by Onkelmat
I´ll try to use the gear comp.
I couldn´t find a tutorial on how to implement comps and .py but maybe it find out today.
I´ve tried to locate the restart cause. The machine still randomly restarts when only the 19k1 is attached to one of the boards. SOmetimes it restarts random sometimes when i move an axis fast or when the hydraulic latches.
I have the feeling it restarts more often, wehn i´ve attached 2 or 3 glasscales.
But then it happens very often when only the mains of the maho is on and i start linuxcnc. Before the gui comes up the pc restarts.
6 years 3 months ago #174067 by RotarySMP
As I said earlier, the instructions for compiling the gearbox.comp ist in the github wiki...
github.com/jin-eld/mh400e-linuxcnc/wiki/...-Component---Testing
Do you still have the Mesa 7i77 powered by the 5i25? If so, the encoders + 7i77 current draw almost definitely exceed the 5i25 current capacity. But I don't know enough about that to know if it is pulling down the PC's 5V rail enough to cause rebooting. Is your PC PSU powered off the MAHO's 110V AC Rail? Have you tried a different PC PSU? The MAHO's 110V AC Rail is certainly affected by the load on the main transformers, as my monitor blanks occasionally when the spindle motor starts.
Time to create page: 0.069 seconds
