- Thank you received: 4
tommylight wrote: 1. Yes it does, but it is not Linux at fault.
2. Why would you delete the complete hal? and Linux will not rewrite anything if not explicitly told to do so.
3. Yes there is, but on a lot of documentation for both the LinuxCNC and cards in use.
4. Yes, you need a DVM with memory function or min/max function.
5. ............... i see PCW has already replied
Did you try any of those things???????????????????tommylight wrote:
That is telling you exactly where the problem is......Onkelmat wrote: this is the situation:
- Maho mains is ON
- the vent for the electirc cabinet is running low, nothing is active. Only power supplies of the maho are energized 19K1 not latched.
- i start Linux cnc
- when the Linuxcnc Splashscreen closes -> restart.1. Yes it does, but it is not Linux at fault.Onkelmat wrote: 1. So this implies something from Linux triggers the restart.
2. I´ve then deleted almost the complete HAL but linux rewrites it..
3. Is there a documentation what LinuxCNC does with the cards on initial start ?
4. Or can i monitor it ?
5. So I think linux is doing something to the cards that causes a restart.
-Plug the PC on another socket in the shop, preferably not the same phase as the Maho,
-find another PC to test with, they are 50$ and up, so not worth the time lost chasing gremlins,
-if you do have a DVM with the above functions, monitor the 5V supply for both min and max values, under no circumstances they should deviate by more than 5%, or from 4.75 to 5.25V. I think for Mesa that should be even lower, like 2%.
-check if the PC power cord has grounding, do not use anything without ground on a machine.
-power the PC and 7i77 without powering the Maho, see if you get restarts. If yes, throw that Pc and get a new one. If no, something is wrong with one of the above or with the wiring/grounding or the supply voltage is dropping to the point of resetting the PC when Maho is turned on.
