That is telling you exactly where the problem is......Onkelmat wrote: this is the situation:
- Maho mains is ON
- the vent for the electirc cabinet is running low, nothing is active. Only power supplies of the maho are energized 19K1 not latched.
- i start Linux cnc
- when the Linuxcnc Splashscreen closes -> restart.
1. Yes it does, but it is not Linux at fault.Onkelmat wrote: 1. So this implies something from Linux triggers the restart.
2. I´ve then deleted almost the complete HAL but linux rewrites it..
3. Is there a documentation what LinuxCNC does with the cards on initial start ?
4. Or can i monitor it ?
5. So I think linux is doing something to the cards that causes a restart.
PCW wrote: At least for debugging, I would not power the 7I77 5V from PC power
because if you have a 5V fault of some kind it will reset the PC
