Retrofiting Scm record 220
- michaeln
- Thank you received: 14
01 Nov 2024 21:08 - 01 Nov 2024 21:15 #313628
by michaeln
Replied by michaeln on topic Retrofiting Scm record 220
@CObra
thank you for your answer.
With help from the NUM support the NUM 1040 controller is now working again and i will not change to LinuxCNC at this machine.
If anybody have problems with this NUM controller:
This NUM 10x0 Controllers have a problem that they sometimes lose files (some machines every year some never in 30 years). If you have a backup (you can get one from SCM) a NUM technican can get your controller working in one hour and he will shows you what to do next time. But he must be in from of the machine because it is not so easy the get the connection.
Last edit: 01 Nov 2024 21:15 by michaeln.
- Thank you received: 7472
01 Nov 2024 22:05 #313634
Replied by tommylight on topic Retrofiting Scm record 220
Nice, thank you for reporting back.
Now you know if something happens later that you can count on support here.
- C0bra
02 Nov 2024 19:02 #313674
by C0bra
Replied by C0bra on topic Retrofiting Scm record 220
Im glad you manage to fix it and is probably much better than any retrofit.
Can you share some details, I would like to do the same but am affraid it would cost too much.
I paid for whole machine and vacuum pump cheaper than it would be for them if they sold it to junk jard as steel waste.
But again am just starting this cnc thing and dont have any business running yet.
- michaeln
12 Nov 2024 10:11 #314311
by michaeln
C0bra
In this forum the personal message is deactivated.
Please send me an email to This email address is being protected from spambots. You need JavaScript enabled to view it. an i will send you the informations.
Time to create page: 0.425 seconds
