Mesa 7I96 + Renishaw LP2 probe
5 years 8 months ago #200091 by BastianMC
Hi Andy,
I use home to home the machine and then use the touch off settings to define my work coordinates. I only home once when I start the machine first time of the day.
5 years 8 months ago #200092 by andypugh
OK, then storing offsets in the tool table should be correct.
5 years 8 months ago #200093 by andypugh
It looks like G10 L11 is intended for this use-case.
linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g10-l1
Though I was actually looking for a G10 variant which set the tool length and position in the machine coordinate system, as I think that generally tool-length probing is done with G93 moves.
The following user(s) said Thank You: BastianMC
Time to create page: 0.149 seconds
