Mesa 7I96 + Renishaw LP2 probe
5 years 9 months ago #195707 by PCW
Replied by PCW on topic Mesa 7I96 + Renishaw LP2 probe
No eBay APP ID and/or Cert ID defined in Kunena configurationI think you need a Renishaw interface box for these
Either the simple hardwired interface (HSI) or one of
the fancier optical or radio links
LP2 manual:
resources.renishaw.com/en/details/instal...-probe-system--79509
A HSI on EBAY (Not sure if this is the right one, more study is needed)
The following user(s) said Thank You: chimeno, BastianMC
5 years 9 months ago #195835 by chimeno
Hello @BastianMC
I have an MP3 probe, I still don't have it connected, there are only two cables
input + input-
I think the easiest thing would be to get a RENISHAW interface, if you can make it work, could you explain how? Thank you.
Greeting
Chimeno
The following user(s) said Thank You: BastianMC
5 years 9 months ago #195904 by andypugh
chimeno wrote: I have an MP3 probe, I still don't have it connected, there are only two cables
input + input-
MP3 is really simple, that is just a switch, no interface needed.
Only drawback is how big they are.
5 years 9 months ago #196034 by BastianMC
I have this coming tomorrow with the mail, i will try and wire it up to the probe and my controller. Will report back if i get a signal then.
resources.renishaw.com/en/details/data-s...interface-unit--7862
5 years 9 months ago #196145 by chimeno
Hello @andypugh,
I've been waiting to spend time with it for a long time, it seems easy, I'll try to try it, thank you very much.
Greeting
Chimeno
5 years 9 months ago #196296 by andypugh
chimeno: For My MP3 I made a shorter arbor (still with the 4 screws and spherical pivot to enable centering) and made a home-made magsafe connector (in case I turned on the spindle with the probe mounted) mounted in a hole drilled in the probe body.
photos.app.goo.gl/tL8dAwzymdTwt8Bx9
Time to create page: 0.279 seconds
