Hurco BMC 30 AP
4 years 11 months ago #227633 by 5_Zylinder
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hi there,
the XYZ axis can now be controlled via Linux CNC and also move.
However, we have not yet made any further settings.
We wanted to put the spindle motor into operation, but unfortunately we didn't succeed.
There are no signals from the encoder to the Mesa card.
The encoder receives 5V (are available), the signal goes to the Yasakawa driver and is processed further. Then the signal comes out of the driver and goes to the Mesa card.
I hope the encoder is not broken.
Turn the spindle by hand, a signal arrives at the Yasakawa driver because several LEDs light up again and again.
4 years 11 months ago #228004 by 5_Zylinder
I think I have a problem with the encoder.
It looks like oil spilled in there.
Has anyone ever disassembled such an encoder, possibly non-destructive?
4 years 11 months ago #228015 by tommylight
Replied by tommylight on topic Hurco BMC 30 AP
Nope.
But as a general rule, they are very sensitive devices and great care must be taken when working with them.
If there is no rust on the disc, a good cleaning should work, use a very soft brush, hot water or rubbing alcohol, pressurized air but at low pressure.
If there is rust, do not bother with it.
4 years 11 months ago - 4 years 11 months ago #228022 by 5_Zylinder
Before I dismantle any more, I'll put the 5V directly on the encoder on Thursday and then I will see if i can measure any signals on the connector.
If it doesn't, there is a problem here.
If you take a closer look, it looks like there is oil on the board.
I can‘t see any rust.
Last edit: 4 years 11 months ago by 5_Zylinder.
4 years 11 months ago #228048 by 5_Zylinder
I found some information about the encoder.
4 years 10 months ago #228462 by 5_Zylinder
here is a little test video.
Unfortunately there are still problems with the spindle.
We just can't get it to work.
Time to create page: 0.427 seconds
