Novakon Mill Conversion - Getting Started
2 years 8 months ago #294040 by PCW
Assuming the C11 breakout does all machine I/O there should be no other
hardware changes needed other than swapping the parallel port with the 6I25.
2 years 8 months ago #294044 by spumco
I also uploaded the mach.xml file, not sure if it is it of any benefit to understand how many IO I need or if I have enough IO?
Yes, it's useful.
Have a look in the file and you can set up a spreadsheet to make it easier to read.
In the xml file you'll see a list of components, and each line has "something...port-N" or similar.  following line has "something...pin-N".
Any line/component where the port/pin number isn't 0 is something that actually exists.  Anything where the port/pin is 0 is a placeholder for Mach3.
So the following lines:
<Motor0Active>1</Motor0Active> <Motor0DirNeg>0</Motor0DirNeg> <Motor0DirPort>1</Motor0DirPort> <Motor0DirPin>3</Motor0DirPin> <Motor0StepNeg>1</Motor0StepNeg> <Motor0StepPort>1</Motor0StepPort> <Motor0StepPin>2</Motor0StepPin>
Tell you that Motor 0 (probably X-axis) has the step pin on port 1, pin 2, and the direction pin on port 1, pin 3.
That info is also available just by looking at the C11 and tracing wires back to the Geckos and limit switches and so forth.
2 years 8 months ago #294057 by tommylight
Note that port numbering might not be the same, it was way to long, but i think mach3 numbers porst from 1 while Linux numbers them from 0.
2 years 8 months ago #294072 by spumco
tommylight post=294057 userid=17274
good point Tommy.  What the xml decoding should do is tell the OP what's connected to the C1, not the port/pin name in LCNC.
2 years 8 months ago #294265 by Whizbang
I may be over thinking things, but I reviewed an old CNC zone where there was debate about which config file to use based on rev of C11 board. I downloaded the zipped software file from the MESA website. I have the C11G rev 8.2, do I use c11g bitfile/pinfile? or c11gx2? something else?
2 years 8 months ago #294267 by PCW
If you have a C11G you should use the C11Gx2 firmware
The difference between the C11 and C11G is that the C11 uses a frequency
to set the spindle analog output voltage while the C11G uses PWM duty cycle.
Time to create page: 0.072 seconds
