Thank you! That did the trick. I did that when I was trying to mash two files together, but when I realized that I could use the wizard i forgot about it plus the wizard lets you select the drive which gives you 500 for that value which maybe keeps you from running away or burning something up but doesn't do much for making the motors turn. I dug the other specs out of my old files for the drive and put them in the wizard and the steppers sound happy again. Now I just have to get the spindle drive to respond and I'll be back where I started
) Thanks again for your quick replies and patience with me.
