Novakon Mill Conversion - Getting Started
2 years 8 months ago #294419 by Whizbang
what you said makes sense and I went back and modified so that there is no parallel port, but I still get the same errors. It seems there is an issue with the actual firmware I think.
After a little conversation on IRC, it seems as though the firmware isn't right and that pins in the C11gx2 pinfile don't all match correctly to my actual pin layout and I may need a custom firmware.
I attached my confirmed ports and pins for the C11G BoB for reference.
2 years 8 months ago #294442 by tommylight
Not the same errors, there are two distinct errors, first ethernet instead of PCI, second non existing parallel port.
So, what error do you get now?
2 years 8 months ago #294458 by PCW
It appears you have not updated the firmware to 5i25_c11gx2.bit
That is, your mesaflash readhmid  list does not match the C11G pinout
To update the firmware, you would need to
sudo mesaflash --device 5i25 --write 5i25_c11gx2.bit --reload
2 years 8 months ago #294563 by Whizbang
So I tried to flash per the command you suggested and got "Can't find bitfile 5i25_c11gx2.bit" . I assume the downloaded file being in my downloads folder is why, but based on notifications from PNCcong when I open about lack of firm ware in lib/firmware/hm2 I tried to create a hm2 folder with 5i25 fold in it and was told I don't have the permission to create a folder in "lib/firmware/". I am very unfamiliar with Linux commands, so I apologize in advance for having such stupid struggles
I do want to confirm something though, the image I last uploaded are the C11g pin configurations I have confirmed on my existing board, if the pins in the C11gx2 pinfile don't match, won't flashing the card not actually fix my issue?
2 years 8 months ago - 2 years 8 months ago #294564 by PCW
You need 5i25_c11gx2.bit to be in the same directory that you run mesaflash from
5i25_c11gx2.bit is in the 5i25.zip file in configs/hostmot2/  so you need to unzip
5i25. zip first and the change to that directory before you run mesaflash.
The pncconf warning can be ignored, that only applies to ancient cards like the 5I20
The pins on 5i25_c11gx2.bit do match your table, though the table is mislabled
in some ways as the C11G uses PWM for the spindle control where the older C11 uses
a stepgen (as its spindle analog out  is frequency controlled)
Also the C11G firmware uses a stepgen to drive the chargepump
Last edit: 2 years 8 months ago by PCW.
2 years 8 months ago #294875 by Whizbang
I flashed my mesa card again following the instruction above from PCW. Rebooted the computer, tried opening LCNC with my config file and these are the errors I am getting. I used the 5i25_C11gx2.bit file.
Time to create page: 0.146 seconds
