Mostly 3D Printed CNC Foam cutter
  • my1987toyota
  • my1987toyota's Avatar Topic Author
  • Platinum Member
  • Platinum Member
17 May 2024 22:01 - 17 May 2024 22:03 #300871 by my1987toyota
Mostly 3D Printed CNC Foam cutter was created by my1987toyota
For over a few months now I have been building a hot wire foam cutter. First I was just trying to make a hot wire bow for cutting foam
and making an air foil for my R/C plane with 3D printed templates and metal foil tape. It sort of worked. But I could never get a
good cut without having to do a lot of sanding and even then it didn't look good. Next I tried to make a gravity actuated foam
cutter like the old Tekoa feather cut foam cutter. It worked better but I kept having problems with the hot wire snagging in unpredictable
ways and not getting a good cut. My next thought was to just build a cnc version that I have seen on YouTube by RCKieth. Lots
of good information on his channel and site by the way. I came across a Thingiverse version that used 3D printed brackets and linear
rails.
www.thingiverse.com/thing:3676825/files
For the control system I am currently using GRBL 5X with the RAMPS 1.4 board. That Said I will be switching to LinuxCNC at some point.
Mostly because I intend to use the same machine to do hot wire and hot pin style foam cutting. I am posting some pictures in later posts
Last edit: 17 May 2024 22:03 by my1987toyota.
17 May 2024 22:27 #300872 by andypugh
Replied by andypugh on topic Mostly 3D Printed CNC Foam cutter
Someone made a fun hot wire cutter some time ago. Imagine a pair of bipods like: wiki.linuxcnc.org/cgi-bin/wiki.pl?Koppi%27s_Toy bolted to the roof of the workshop, with a hot-wire "bow" hanging between them.
I thought it was clever at the time, but can't currently find any pictures.
Forum thread: forum.linuxcnc.org/10-advanced-configura...tter?lang=en&start=0
The following user(s) said Thank You: my1987toyota
  • Moderator
  • Moderator
17 May 2024 22:51 #300873 by tommylight
Replied by tommylight on topic Mostly 3D Printed CNC Foam cutter
Wiki's certificate has expired!
A loooooong time ago i built a 1X1X2 meter cut area foam cutter, now you reminded me i never ever took any picture of it, shame on me as some 2 months ago i was there and watched it working. Over 15 years for sure...
What size did you go for?
And use a spring for the Nichrome wire, but do not send the power through it.
Having over 2 meters of wire dangling taught me some things the hard way! :)
  • my1987toyota
  • Platinum Member
  • Platinum Member
17 May 2024 23:05 #300874 by my1987toyota
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
  • my1987toyota
  • Platinum Member
  • Platinum Member
17 May 2024 23:07 #300875 by my1987toyota
the cutting bow
  • my1987toyota
  • Platinum Member
  • Platinum Member
17 May 2024 23:21 - 17 May 2024 23:53 #300876 by my1987toyota
so basic travels are
450mm or  17.7in. in X travel
350mm or 13.78in. in Z travel
and when equipped
700mm or 27.56in. in Y travel
Though the photos don't show the machine in full setup configuration
it will be 1000mm wide X 600mm long x around 500mm tall.
current control is for now GRBL 5X
and RAMPS 1.4 break out board
The bow uses a 48in. long  1in. X 1in. X 0.0625 wall aluminum boom
I 3D printed the Isolator adapters out of PETG and used 2
carbon fiber arrow shafts cut in half for the tensioner posts.
I retained the threaded ends for the wire attachment and electrical
connections. I use a 22ga. nichrome wire for the hot wire.
For power supply I use a 450 watt 24 volt std power supply
and I use a 30 amp PWM brushed motor speed controller
to dial in the energy needed for the wire. That also means
I can use thinner nichrome wire if I so choose.
many changes coming soon
Last edit: 17 May 2024 23:53 by my1987toyota. Reason: adding info
  • Moderator
  • Moderator
18 May 2024 00:00 #300879 by tommylight
Do you need it to cut 4 axis or just 2 axis?
If 4 how did you solve the wire length changing issue?
I used 2 bearings so the wire dips in between them and also connected the power to those bearings mount, the the spring is set some 25CM/10" to the side. Spring was from some type very thin (8-10mm?) of car bonnet shock absorber, had good linearity for about 20cm of stretch then it would start to harden.
  • my1987toyota
  • Platinum Member
  • Platinum Member
18 May 2024 00:49 - 18 May 2024 00:51 #300882 by my1987toyota
I actually will be using it in 4 axis configuration. Though my Slow ultra stick will be using straight wing cuts.
That's why I am using a bow to handle the wire tension. The attached picture shows the wire yoke. It's designed
to keep the wire mostly in place but will allow it to slide between the two metal washers and also deal with the angular
alignment when the two Z axis are not parallel to each other . the bearings will also allow
for angular misalignment of the two X axis. As I am typing this I am starting to realize that I may need to do a video
showing the misalignment capabilities of how the system works. Fortunately I have time this weekend to do it.
Last edit: 18 May 2024 00:51 by my1987toyota.
  • Moderator
  • Moderator
18 May 2024 01:00 #300883 by tommylight
Yes, videos ! :)
Leme see if i can find any of my smaller foam cutter made some 12 years ago...
  • my1987toyota
  • Platinum Member
  • Platinum Member
18 May 2024 11:11 #300905 by my1987toyota
Those are some really nice machines you have built their.
I am going have to be careful it looks like it becomes an addiction. LOL
Time to create page: 0.876 seconds
