New ethercat / probe basic control for minimonster
- ihavenofish
- Thank you received: 286
08 Feb 2025 23:41 #321029
by ihavenofish
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
no wired connection.
fixed now. this is my frustration with linux. it said you are missing this file, put it on a usb and continue. NOWHERE does it say no, don't do that at all, go get this .deb file of intel stuff instead.
They first make it deliberately difficult, then make the instructions deliberately obtuse assuming everyone already knows everything there is to know about linux.
And then they wonder why it never really makes more headway with the masses.
Well that was a waste of several hours for nothing.
- ihavenofish
09 Feb 2025 00:02 #321032
by ihavenofish
finshed installing.. reboots..... no operating system installed.
*slams head on desk*
Now what? its the only disk in there.
- Thank you received: 7481
09 Feb 2025 00:08 #321033
Replied by tommylight on topic New ethercat / probe basic control for minimonster
Try Linux Mint Debian Edition 6
www.linuxmint.com/download_lmde.php
Try the live version, if everything works, almost always it will work after installing it on the drive.
To install LinuxCNC use the same
sudo apt install linuxcnc-uspace
- ihavenofish
09 Feb 2025 00:17 #321035
by ihavenofish
Already done here.
The no OS found is a lenovo thing I forgot about. needs a bios flash. doing that now.
- ihavenofish
09 Feb 2025 01:27 #321037
by ihavenofish
it wont update the bios cause it cant find the usb drive.
I'm going to eat a pizza and scream for a bit.
Haha.
Haha.
- ihavenofish
09 Feb 2025 04:29 #321041
by ihavenofish
Mmm, pizza fixes everything.
For the curious who might want to use lenovo tiny pcs:
- The pc needed a bios update to disable CSM mode. (legacy compatibility) and turn secure boot off.
- The bios needed to go on a bootable DOS stick, which was not super clear in the instructions and its been AGES since that was a thing haha so I just forgot.
- Once I got the bios on I still needed to reinstall linuxcnc cause I guess the boot record was still messed up.
After all that, its fine. Now to do the work I intended to do like 11 hours ago!
I need a nap.
I need a nap.
- Thank you received: 4149
09 Feb 2025 06:11 #321043
Replied by rodw on topic New ethercat / probe basic control for minimonster
11 hours you've done well!....
- ihavenofish
09 Feb 2025 19:43 #321104
by ihavenofish
Hmm. Seems I cant really do much without having the drives here. But how deal with the rs485 for the spindle?
I see some people using usb adapters, but I have a real serial port as well, can that be used instead?
09 Feb 2025 20:04 #321109
Yes, much better! Buy a serial port to RS485 adapter rather than a USB one.
Aussie link for example
core-electronics.com.au/rs-232-to-rs-485...hSu9V9RoC41AQAvD_BwE
- ihavenofish
09 Feb 2025 21:52 #321120
by ihavenofish
Apparently the serial is through a special cable on these, not just the normal 2x12 board pins and those cables are are and expensive. sigh.
How much worse is the usb adapter? This is not a critical application really so if it lags some milliseconds I don't think it matters. The most critical thing is being able to respond to an alarm and stop the machine.
Time to create page: 0.278 seconds
