New ethercat / probe basic control for minimonster
- ihavenofish
- Thank you received: 286
05 Mar 2025 05:57 #323230
by ihavenofish
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
So now I'm stuck at this step. it says git command not found....
If you are using cia402 compatible drives:
cd ~/dev
git clone github.com/dbraun1981/hal-cia402
cd hal-cia402
sudo halcompile --install cia402.comp
cd ~/dev
cd hal-cia402
- Thank you received: 4149
05 Mar 2025 06:08 #323231
Replied by rodw on topic New ethercat / probe basic control for minimonster
try
sudo apt install linuxcnc-uspace-dev
halcompile is part of the dev package.
05 Mar 2025 06:09 #323232
also you may need
sudo apt install git
- ihavenofish
05 Mar 2025 06:12 #323233
by ihavenofish
thanks
now i get
fatal: could not create work tree dir 'hal-cia402': Permission denied
now i get
05 Mar 2025 06:14 #323234
not sure on what program?
- ihavenofish
05 Mar 2025 06:15 #323235
by ihavenofish
thats after this line
05 Mar 2025 06:16 #323236
I think you are in the /dev folder, not ~/dev
note the ~ for home folder.
- ihavenofish
05 Mar 2025 06:18 #323237
by ihavenofish
i see. cause i tried ~/dev and it says no such folder
05 Mar 2025 12:21 #323253
git clone puts the folder with the same name as the repository in the folder you run the command in. have a look in the file explorer
I tend to create a new folder ~/devel and put all my cloned repos in it. I used to use ~/dev under my home folder but it is easy to get mixed up with the system folder as you found out
- ihavenofish
05 Mar 2025 15:15 #323276
by ihavenofish
so to be clear, I need to make this folder. it is not one that should already exist?
Time to create page: 0.186 seconds
