- Thank you received: 502
Cad/Cam software for Linux
- meister
4 years 2 months ago #250188
by meister
Replied by meister on topic Cad/Cam software for Linux
there are 2 different ways to install:
* pip3 install viaconstructor (this will install it to you system)
or
* git clone github.com/multigcs/viaconstructor.git (this will get the sources)
* pip3 install -r requirements.txt (this will install the depend's)
from Source you can start with:
bin/viaconstructor tests/data/simple.dxf
or From System (installed via pip)
viaconstructor PATH_TO_YOUR_DXF
or
- mgm
- Thank you received: 13
- meister
4 years 2 months ago #250211
by meister
You are using Python3.6, this will only works with Python3.9 and newer
, sorry
- meister
4 years 2 months ago #250233
by meister
if no other way works, you can try the experimental App-Image:
wget multixmedia.org/viaconstructor-0.3.3-x86_64.AppImage
chmod +x viaconstructor-0.3.3-x86_64.AppImage
./viaconstructor-0.3.3-x86_64.AppImage PATH_TO_YOUR_DXF
- mgm
- meister
4 years 2 months ago - 4 years 2 months ago #250242
by meister
hmm, which distribution do you use ?
on Debian/ubuntu you can try:
apt-get install python-matplotlib-data
Last edit: 4 years 2 months ago by meister.
Time to create page: 0.531 seconds
