- Thank you received: 502
Cad/Cam software for Linux
- meister
4 years 1 month ago #252399
by meister
Replied by meister on topic Cad/Cam software for Linux
- phillc54
- Thank you received: 2100
4 years 1 month ago #252497
by phillc54
Replied by phillc54 on topic Cad/Cam software for Linux
That was quick work.
The leads seem to work very well, it took me a long time to figure out that a lead would not appear until the start point was manually set. I would think that having them applied at the starr if they are enabled would be ok. I did try it with these lines commented out and it seemed to work without issue.
I did a quick video of my mouse issue trying to set the start points.
# if not polyline.start:
# # only if a start point is set
# lead_in_active = "off"
# lead_out_active = "off"
- meister
4 years 1 month ago - 4 years 1 month ago #252498
by meister
i will get a mac soon, then i can try to fix the mouse problem.
i have only a mouse problem on parts of closed arcs .
the 'only if a start point is set' thing is because the auto start-points are in corners, and this will not really work in most cases.
EDIT: new thread -> forum.linuxcnc.org/31-cad-cam/46947-viac...am-for-linux-and-mac
Last edit: 4 years 1 month ago by meister.
Time to create page: 0.814 seconds
