Cad/Cam software for Linux
4 years 2 months ago - 4 years 2 months ago #250382 by meister
Replied by meister on topic Cad/Cam software for Linux
There is no undo function, you can only reload the file
Most things worked for me :)
todo:
bugfixes
editable tool and material tables
toolbutton's.....
nice to have:
presets (at the moment i save and load it as extra config file)
better tab support (it is limited to lines and arcs longer than 10mm i think)
more pocket types and better path planning inside pockets
converting spline/bezier into arcs
maybe better INCH support
win/mac support, but this is not so easy :(
and all good idea's from outside :)
Last edit: 4 years 2 months ago by meister.
4 years 2 months ago #250383 by mgm
Replied by mgm on topic Cad/Cam software for Linux
OK well, you still have something to do there
Would it be possible to add viaconstructor as a tap in Axis?
But I have no idea if this is feasible and what kind of effort this entails and if this is useful at all!
4 years 2 months ago #250384 by meister
i take a short look yesterday about axis tab integration because i think i have read in the past that dxf2gcode can do that,
but i can not found it anymore.
If you have a useful link, i can try it
4 years 2 months ago #250385 by mgm
4 years 2 months ago #250387 by meister
Cool, thanks
@all
if someone has improvement suggestions, so that it could improve your workflow or fits in at all,
I would be happy about tips / suggestions. I use the CNC also only for the hobby and have no idea what requirements are otherwise so, but would like to make it also usable for others.
sometimes it also opens me up to new approaches i had not thought of
4 years 2 months ago - 4 years 2 months ago #250397 by meister
now i can open an dxf/svg in axis, this starts viaconstructor und returns the gcode back to axis/linuxcnc :)
but i don't know how to embed the gui into axis tab's :(
  it must be possible, because pyVCP uses also pyqt5, but for what ?
Time to create page: 0.334 seconds
