D510M0 build
29 Jun 2011 18:46 #10970
by BigJohnT
Replied by BigJohnT on topic Re:D510M0 build
Well, you don't need to "install" a parallel port for EMC, only know it's address or the index. In a terminal window type lspci -v and find your pci parallel port. It might have several addresses and you will just have to pick one at a time till you find the actual one. An example is here:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Hooking_Up_A_MPG_Pendant
29 Jun 2011 23:26 #10983
Replied by andypugh on topic Re:D510M0 build
welderfabrod wrote:
it's
I suspect you might have missed out a space, or a slash, or confused i for l?Andy did that and I get the message no such file or directory,
it's
cat /proc/ioports/
You are nowsorry I'm not a linux user.
![:-) :-)](/media/kunena/emoticons/smile.png)
- welderfabrod
30 Jun 2011 10:35 #10991
by welderfabrod
Replied by welderfabrod on topic Re:D510M0 build
Thanks for your help guy's all is running smoothly now.
Can anyone answer my other question on where to get a parallel port header here in the UK. I've searched the net and come up blank so far.
Rod
Rod
30 Jun 2011 10:43 #10992
welderfabrod wrote:
I already answered: www.linuxcnc.org/component/option,com_ku.../lang,english/#10951Can anyone answer my other question on where to get a parallel port header here in the UK.
- welderfabrod
30 Jun 2011 11:12 #10994
by welderfabrod
Sorry Andy fell asleep and missed that. Donno why they didn't show when I did my search.
Thanks Rod
Thanks Rod
30 Jun 2011 11:35 #10997
by BigJohnT
The search function on the forum is a bit flaky and I use the site option with google like this
text I'm searching for site:http://www.linuxcnc.org
