Lost in space
- TarHeelTom
Built up a "new" computer with a D10MO board, etc. Unknowstto me, the board comes with one parallel port built in, but with only a header plug. Ordered a "PLATE25" header plug to DB25 connector, but it was actually wired backwards. Finally got it working by opening the header connector and reversing the ribbon cable. That made port 0 run, but in the midst of that port 1 decided not to work, and on the next EMC2 load, EMC refuses to load, then the computer won't boot. Pulling the 2nd parallel port board allowed the computer to boot, but now EMC2 won't load.
One interesting aspect here is that I did NOT make any HAL changes in the middle of this, but have later as part of the trouble shooting. Nothing seems to help.
Along the way I replaced the extra parallel port board with a single board containing two parallel ports. It appears to install, but I'm unable to run its driver installation program, and its error message doesn't make any sense at all.
I'm at the point of thinking that I need to reinstall EMC2, but couldn't find the deb file on the web site.
Anyone got an ideas?
- TarHeelTom
- TarHeelTom
And here's the search for the new parallel ports.
tomwade@Bridgeport:~$ lspci
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01)
00:1c.2 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 3 (rev 01)
00:1c.3 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 4 (rev 01)
00:1d.0 USB Controller: Intel Corporation N10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 01)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
05:00.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
05:00.2 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
tomwade@Bridgeport:~$ lspci -v
Subsystem: Intel Corporation Device 4f4d
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
Kernel modules: intel-agp
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at e0300000 (32-bit, non-prefetchable) [size=512K]
I/O ports at 30c0
Memory at d0000000 (32-bit, prefetchable) [size=256M]
Memory at e0200000 (32-bit, non-prefetchable) [size=1M]
Kernel driver in use: i915
Kernel modules: i915
Subsystem: Intel Corporation Device d618
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at e0380000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 80000000-803fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000e00fffff
Kernel driver in use: pcieport
Kernel modules: shpchp
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: 80400000-805fffff
Prefetchable memory behind bridge: 0000000080600000-00000000807fffff
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00005000-00005fff
Memory behind bridge: 80800000-809fffff
Prefetchable memory behind bridge: 0000000080a00000-0000000080bfffff
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00006000-00006fff
Memory behind bridge: 80c00000-80dfffff
Prefetchable memory behind bridge: 0000000080e00000-0000000080ffffff
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at 3080
Kernel driver in use: uhci_hcd
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at 3060
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 3040
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 3020
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01) (prog-if 20)
Memory at e0384400 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1) (prog-if 01)
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: e0100000-e01fffff
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA IDE Controller (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 30b8
I/O ports at 30cc
I/O ports at 30b0
I/O ports at 30c8
I/O ports at 30a0
Memory at e0384000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ata_piix
Flags: medium devsel, IRQ 11
I/O ports at 3000
Kernel modules: i2c-i801
Subsystem: Intel Corporation Device d615
Flags: bus master, fast devsel, latency 0, IRQ 28
I/O ports at 2000
Memory at e0004000 (64-bit, prefetchable) [size=4K]
Memory at e0000000 (64-bit, prefetchable) [size=16K]
Expansion ROM at e0020000 [disabled] [size=128K]
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Subsystem: Device a000:2000
Flags: bus master, fast Back2Back, medium devsel, latency 32, IRQ 10
I/O ports at 1018
I/O ports at 1010
Memory at e0103000 (32-bit, non-prefetchable) [size=4K]
Memory at e0102000 (32-bit, non-prefetchable) [size=4K]
05:00.2 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
I/O ports at 1008
I/O ports at 1000
Memory at e0101000 (32-bit, non-prefetchable) [size=4K]
Memory at e0100000 (32-bit, non-prefetchable) [size=4K]
tomwade@Bridgeport:~$ clear
I/O ports at 30c0
I/O ports at 3080
I/O ports at 3060
I/O ports at 3040
I/O ports at 3020
I/O ports at 30b8
I/O ports at 30cc
I/O ports at 30b0
I/O ports at 30c8
I/O ports at 30a0
I/O ports at 3000
I/O ports at 2000
I/O ports at 1018
I/O ports at 1010
I/O ports at 1008
I/O ports at 1000
Tom
You can check if the OS found the new card (after rebooting)
by running lspci in a terminal window like
lspci
and searching for parallel ports
or fancier:
lspci -v | grep -i parallel
- TarHeelTom
OK so it found the parallel ports just fine. now you just need to find which of the listed addresses are the ones you need. You could also try the index method of accessing the ports ( with this method your ports will be 0,1,2)
But the original, on-board parallel port on the motherboard is still there, though i probably won't be using it.
So, really, I'll have 0, 1, 2
Tom
Your original error was
Bridgeport_2.hal:11: parameter or pin 'parport.0.reset-time' not found
that is almost certainly because your hal file was trying to specify a non-existent parport in the line
loadrt hal_parport cfg="0x278 out" or whatever address your hal file specified
Your on board parport should be accessible from BIOS and you can get the address from there and check that it is in EPP mode and not AUTO or similar.
Usual addresses are 0x278 or 0x378
Your PCI board addresses appear to be 0x1008 and 0x1018
So loadrt hal_parport cfg="0xnnn out 0x1008 in 0x1018 in" where nnn is the address of your built in port should load them all (assuming the NetMos card works in input mode which I think the 9865 chip does)
Thereafter you can address them a parport.0 parport.1 and parport.2
PS
I have just found your .hal file you attached, thought it was missing
It contains
#loadrt hal_parport cfg=" 0x378 out "
#loadrt hal_parport cfg="0x378 out 0x1008 in " loadrt hal_parport cfg="0x1018 out 0x1008 in "
setp parport.0.reset-time 1000
So you are not loading anything because it is all commented out, so the setp line is going to throw an error.
- TarHeelTom
Hi
<snip>
It contains
Ooops. Glad you caught that. It IS there, but a line feed got deleted. Now to go fix that and try again.
Thanks for catching that.
Tom
