joint 0 limit error - setting up debounce.
02 Aug 2011 10:09 #12123
Replied by andypugh on topic Re:joint 0 limit error - setting up debounce.
whampoo wrote:
In your X axis example you would probably want to keep the Axis max and min as 14 and -14, then HOME as 0, SEARCH_VELOCITY negative, LATCH_VELOCITY positive, and HOME_OFFSET -14.1 (the home switch wants to be fractionally outside the working envelope if it doubles as a limit switch)
Make the homing velocity in the INI file negative and it will home in the opposite direction. You might want to do that in Stepconf so that it doesn't get over-written.Thank you everyone for you help OI added to code that Andy suggested and everything seems to be working now..... Except its homing to the max switch and not the min/home switch
There are diagrams here: linuxcnc.org/docs/html/config_ini_homing.html1) should I be using -14 to +14 in the config file with home being 0.0 of the x axis and y axis -13 to 13 with 0.0 being home ?
04 Aug 2011 04:18 - 04 Aug 2011 04:19 #12166
by whampoo
Replied by whampoo on topic Re:joint 0 limit error - setting up debounce.
Hi All,
Thanks for all the help everything is working great now. Hopefully I will be more fluent in EMC and the CNC language in the next few months.
Thanks again,
Joel
Thanks again,
Joel
Last edit: 04 Aug 2011 04:19 by whampoo.
Time to create page: 0.070 seconds
