4 Axes Machine Questions
- Thank you received: 1479
29 Sep 2011 16:25 #13539
Replied by Todd Zuercher on topic Re:4 Axes Machine Questions
If you are talking about changing this line
net Apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
to
net Zpos-fb stepgen.2.position-fb => axis.3.motor-pos-fb
Yes I tried that. and it had no effect.
But I did notice that while I have the net Apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd line short circuited, when I try to jog it does move the A axis, just a tiny amount before it gives the joint 3 error. Is there a way to cut this off further upstream, so that what ever is seeing the error sees this as a commanded movement instead of an error?
to
29 Sep 2011 16:48 #13540
Replied by andypugh on topic Re:4 Axes Machine Questions
Todd Zuercher wrote:
No, that's not really what I had in mind.
The feedback loops shouldn't change and can be: (check the pin names, I am at work)
net Z-fb axis.2.motor-pos-fb <= stepgen.2.motor-pos-fb
net A-cmd axis.3.motor-pos-cmd => axis.3.motor-pos-fb # Short circuit
The Z command stays the same at all times.
net Z-cmd axis.2.motor-pos-cmd => stepgen.2.position
Now, to link motor 3 to the Z axis:
unlinkp axis.3.motor-pos-cmd
net Z-cmd axis.3.motor-pos-cmd
And to make it follow the A-word in the G-code
(Again, all untried and untested)
to
12 Sep 2015 04:03 - 12 Sep 2015 04:03 #62481
Now to dredge up an old thread.
I think I've finally mostly solved this!
I made two custom M-codes (M122 and M123) that temporarily slave the movement of the W axis to the Z.
It works with both a stepper config (in simulation at least) and I have it running on a servo machine as well.
One bug that I still have to squash though is that while slaved the following error of the W isn't monitored. No big deal for a stepper system, but a little scary with a servo. I have some ideas but have not taken the time to implement them yet.
Here is the stepper config as an example for others to look at. (The M-code files need to be located in the right place to work as well.)
Last edit: 12 Sep 2015 04:03 by Todd Zuercher.
18 Sep 2015 20:25 #62747
Ok, I think I have a feedback system in place for my servo configuration.
What I did is to use sum2 to add (subtract actually) the axis.8.motor-pos-cmd and the PID error for the W axis. Feeding that to the mux2 that short circuits the W feedback while operating in ZZ mode.
It seems to work ok now, but the very first time I started the config, it did a false runaway on the W axis when I switched to ZZ mode (numbers on the DRO were moving but the motor wasn't). After a restarting Linuxcnc it has behaved fine. (Fingers crossed)
Attached is the servo config.
The following user(s) said Thank You: akb1212
13 Feb 2016 14:36 #70064
I've fixed the following error problem with the servo config, something about how the movement order and M-code execution order worked against each other.
Time to create page: 0.095 seconds
