Joint 3 Following Error
- gerrybacsik
18 Sep 2011 01:22 #13246
by gerrybacsik
Joint 3 Following Error was created by gerrybacsik
Any one know what this refers to? 1/4 into the run this shows up & stops the mill
- Thank you received: 2160
18 Sep 2011 05:19 #13250
Replied by cmorley on topic Re:Joint 3 Following Error
It mean emc ask for movement and the encoder or stepgen did not move enough to be within the max following error specification.
Without more info we can't help anymore then that.
for instance are you using servos or steppers ( I bet steppers) could be your acceleration or max velocity is too high.
are you using software stepping or hardware stepping?
- BigJohnT
- Thank you received: 1176
18 Sep 2011 12:05 #13256
by BigJohnT
Replied by BigJohnT on topic Re:Joint 3 Following Error
- gerrybacsik
18 Sep 2011 16:52 #13258
by gerrybacsik
Replied by gerrybacsik on topic Re:Joint 3 Following Error
Using a sherline lath. Steppers i'm assuming.
The parts I'm milling are very small. 0.5mm ball nose with 25% overlap. Need to bring out detail in the piece. The mill is very new. Backlash seems to be non existent. But that could still be a problem. Is there some way to adjust the following error specification?
I've slowed the speed down to a crawl but still have the problem.
- gerrybacsik
18 Sep 2011 16:56 #13259
by gerrybacsik
I'm not sure I understand your question about software or hardware stepping. I use a Rhino CAM software for the g-code.
- gerrybacsik
18 Sep 2011 17:03 #13260
by gerrybacsik
Great information!! I sort of have an understanding. Is there a translation for simple folk like me?
18 Sep 2011 19:51 #13265
See the problem for us is your giving us all most no information.
It's like saying my car stopped running - whats the problem?
Is this stock sherline controls ? sftermarket ?
What version of EMC are you using?
If you are using AXIS, look for the help button. select 'about AXIS' and it should tell you the version of EMC
Are you familiar with EMC configuration files? can you post them?
Is this a new problem or just came about?
If this is steppers then the problem most likely has always been there and need configuration changes.
If servos then physical problems such as the ways not moving freely could do this.
changing the following error setting will change the accuracy of the machine.
- gerrybacsik
18 Sep 2011 19:58 #13267
by gerrybacsik
Now you know how I feel. Joint 3 following error???Lots of possible problems nothing definite.
18 Sep 2011 20:11 #13269
Yes I do. Many of EMC's messages are cryptic.
Joint 3 by the way is most likely the a axis on a mill.
Do you have an a axis?
Are you using UBUNTU operating system? do you know what version ?
earlier you mentioned a sherline lathe then said mill. Which is it?
- gerrybacsik
18 Sep 2011 20:22 #13270
by gerrybacsik
Sorry, It is a mill. Yes I do have an " a" axis. I use the Ubuntu operating system 10.04 LTS The mill is stock Sherline. As for the EMC software. It is Axis version 2.4.3
