Joint 3 Following Error
18 Sep 2011 20:35 #13271 by cmorley
Replied by cmorley on topic Re:Joint 3 Following Error
ok I assume you know the config name that you use to start EMC
if you look in your home folder for emc2/configs/name-of-your-config
We are interested in the file ending in INI can you post the contents of it?
or can you compress the whole config file and post it?
I am not going to have to time to look at it now but maybe someone else will.
Chris M
19 Sep 2011 03:26 #13276 by gerrybacsik
Replied by gerrybacsik on topic Re:Joint 3 Following Error
What sorts of things am I looking for within the file?
19 Sep 2011 03:31 #13277 by gerrybacsik
Yes, It seems to be the "a" axis that is causing the problem. It speeds up & slows down on a simple rotational cut with no "z or y" movement to contend with.
19 Sep 2011 10:54 #13286 by Rick G
Replied by Rick G on topic Re:Joint 3 Following Error
You could first try running the A axis at a slower speed to see if the problem goes away.
You can try this by using the speed override slider on the display and reduce the speed by say 50%
Or use MDI COMMANDS to move the axis with slower speeds.
The real adjustments you need to make as John and Chris have pointed out is in your .ini file. Find the section for the a axis and edit (reduce) MAX_VELOCITY and or MAX_ACCELERATION save the file and try again.
•FERROR to small
•MIN_FERROR to small
•MAX_VELOCITY to fast
•MAX_ACCELERATION to fast
•BASE_PERIOD set to long
•Backlash added to an axis
Any of the above can cause the RT pulsing to not be able to keep up the requested step rate. This can happen if you didn't run the latency test long enough to get a good number to plug into the Stepconf Wizard or if you set the Maximum Velocity or Maximum Acceleration too high.
If you added backlash you need to increase the STEPGEN_MAXACCEL up to double the MAX_ACCELERATION in the AXIS section of the INI file for each axis you added backlash to. EMC uses "extra acceleration" at a reversal to take up the backlash. Without backlash correction step generator acceleration can be just a few percent above the motion planner acceleration.
Rick G
19 Sep 2011 10:58 #13287 by Rick G
Depending on how the acceleration is set that is what you would expect..start slow move up to speed then slow down to stop. That is adjusted in the .ini file and what might need to be changed along with the top speed.
Rick G
19 Sep 2011 14:08 #13293 by gerrybacsik
I can change speed with the speed override slider. But it slows all movements down. I've tried to lower cutting speed with MDI COMMAND but it does not seem to make any difference. I can change all other speeds. That seems wierd.
I have found MAX_VELOCITY and MAX_ACCELERATION files. I will try changing these to see if anything happens.
What are my FERROR settings? & BASE_PERIOD settings for?
19 Sep 2011 15:08 #13298 by BigJohnT
Replied by BigJohnT on topic Re:Joint 3 Following Error
Here is the doc for all the ini file settings
www.linuxcnc.org/docview/html/config_ini_config.html
19 Sep 2011 15:17 #13300 by gerrybacsik
I tried a simple program to test rotational speed
G1 A0 F400
G1 A360 F200
Speeds up & slows down fine.
Why I can change MDI cutting speed commands from CAM generated program but it doesn't affect speed speed I don't know?
I will play with it some more see what I can find.
19 Sep 2011 17:23 #13309 by Rick G
Now would be a good time to run the latency test.
Go to applications then cnc then latency test. Let it run a while. You can use that info to find the base period that you can run.
When you lower the MAX_VELOCITY do it in the A axis section, it will change only the A axis, which is what you want.
If you have a move that moves a X, Y, or Z (linear) axis and the A axis (rotary) at the same time the A axis will try to keep up with the linear axis, so it may in fact be moving at it's maximum speed.
Rick G
19 Sep 2011 23:31 #13320 by gerrybacsik
Interesting info RIck. I did change my setting on the "A-AXIS", unfortunately, it didn't help. I might have to change XY&Z too. Called Sherline for benchmark settings on A-AXIS. They were not set properly from factory. Never thought to ask about XY&Z axis. Will call tomorrow to see what they need to be.
