Reverse spindle no pwm
- grandixximo
- Thank you received: 10
i'm using pdm mode with no offset and a scale of 18900
max-dc 0.4
the spindle at maximum speed is roughly 6500RPM
i do not use outputs to turn the spindle on, the spindle is stopped at pwm 0
Also i am using the soft start hal lines
and i only connected net spindle-rev motion.spindle-reverse => parport.0.pin-17-out
any help???
- grandixximo
- grandixximo
- BigJohnT
- Thank you received: 1176
- Thank you received: 5262
- grandixximo
linuxcnc.org/docs/html/examples_spindle....#Spindle%20Direction
it says that all you have to do is connect a pin to have the spindle running in the opposite direction, but actually if you don't hijack the spindle speed out with abs you will not get any frequency out of pwmgen
- Thank you received: 2161
This would seem to be right but I have not dug in to see yet.
- grandixximo
- BigJohnT
I think a good place to add this in the docs would be here
Can you give me an example of using the abs and I'll add it to the docs as soon as I get past my dial up wows...
PWM mode 1 should do the right thing without adding any other comps
if PWM mode 1 does not do the right thing, the PWM comp needs to be fixed
