Reverse spindle no pwm
24 Mar 2012 11:52 #18754 by BigJohnT
Replied by BigJohnT on topic Re:Reverse spindle no pwm
Maybe a radio button to select the pwmgen mode would be the most straight forward...
24 Mar 2012 21:17 #18765 by cmorley
Replied by cmorley on topic Re:Reverse spindle no pwm
ok I think I'm was a bit slow yesterday.
Probably what Peter meant and I didn't pick up on is that there is no reason we wouldn't want the PWM signal to respond to the spindle speed.
so if we set up type 1 PWM all the time a user can choose the signals as he likes:
one direction - spindle PWM and spindle cw ( using the cw signal as an enable pin )
two direction - spindle PWM and cw and ccw (for say using two relays to change direction)
two direction - spindle PWM and cw (for converting to positive and negative analog signal)
Does this make sense ?
25 Mar 2012 14:38 #18784 by PCW
Replied by PCW on topic Re:Reverse spindle no pwm
Sounds a lot better than not working
and needing a comp to fix
27 Mar 2012 00:51 #18819 by cmorley
I pushed a fix for this to 2.4 and 2.5.
spindle pwm will now be type 1
Time to create page: 0.055 seconds
