can't open after fixing smi issues
Really Andy, the only time you _must_ reboot Linux is when you want to change monolithic kernel code. Something RTAI isn't.
For fun, save this as fault.comp then sudo comp --install fault.comp
component fault "designed specifically to break LinuxCNC";
license "GPL";
author "Andy Pugh";
option extra_setup yes;
pin out unsigned dummy = 666;
function _;
FUNCTION(_){
//It will never even get this far
EXTRA_SETUP(){
*(int*)0 = 0;
then:
halrun
loadrt fault.comp
exit
Then try to recover the system so that halrun can be invoked again without a reboot.
I hope you can find a way, it will save me hours.
(currently I am struggling with a slightly more subtle issue of passing fixed-length strings between modules, which may or may not be initialised but the effect is the same)
MESSAGE FOR THE OP:
Don't worry about this, it is not relevant to the typical user experience.
sudo init 1
login as root
init 2
Because quite frankly I don't know the first thing you're on about with any of this. I still give fair odds that'd work. Technically it isn't rebooting either. Although I'll admit it looks an awful lot like rebooting. There may be less invasive fixes though. But I feel like I'm getting a bit of the mushroom treatment now. You know kept in the dark, and fed ....
So that is the best I can come up with for now. Well, maybe not, but it's the best I'm going to come up with considering what I have to work with.
I did, I had to reboot. In fact dmesg said:It is your experiment Andy so you try it,
[ 4057.142301] RTAPI: Task 1[eed35800]: Fault with vec=14, signo=11 ip=fb598d71.
[ 4057.142305] RTAPI: This fault may not be recoverable without rebooting.
I can try it, I am open to suggestions.sudo init 1
login as root
init 2
You have me puzzled now. I thought you were saying that there were simpler ways to untangle a mess of kernel modules other than rebooting. I was rather hoping you were right.Because quite frankly I don't know the first thing you're on about with any of this. I still give fair odds that'd work. Technically it isn't rebooting either. Although I'll admit it looks an awful lot like rebooting. There may be less invasive fixes though. But I feel like I'm getting a bit of the mushroom treatment now. You know kept in the dark, and fed
I just provided a minimal realtime module that puts the system in the state I was describing.
I really do know next-to-nothing about Linux. It might seem odd that someone like me would mess about with Kernel modules, but it's true. I like my hobbies to be beyond my capabilities.
- Banana Jack
what a beautiful, beautiful sight...it's been much too long...
It's not that beautiful, you still have the "Realtime Delay" message
![:-( :-(](/media/kunena/emoticons/sad.png)
In any event reading your dmesg error I think you might have better luck in June, and that isn't so far off now. May is a silly month!
Next thing you know you'll be singing jigs!
Don't ever learn anything about Linux, because as soon as you do some clown will just end up changing it all on you anyways. I just learned termcap no longer exists! I can't make heads or tails out of terminfo either. How am I supposed to pick colors for my terminals now?
I did learn about this bizarre little program called grc though. It doesn't do much for me with dmesg, but it sure can make syslog pretty.
- Banana Jack
yeah after i posted that i just knew somebody would notice...i hadn't activated the smi bypass yet at that point. we should be good now. i'm about to go down there to play with it.
and i ALMOST got internet on it too, it blew my mind...followed some tutorial and had no idea what i had just done, and then it worked.
![:woohoo: :woohoo:](/media/kunena/emoticons/w00t.png)
and i ALMOST got internet on it too, it blew my mind...followed some tutorial and had no idea what i had just done, and then it worked.then i unplugged everything and put it back where it should be and then turned it on and i had no idea what the internet was anymore.
No internet? That can make some things more difficult to do. Even your boot process is affected by not being able to establish a net connection. So there really is no way to get around the impact. Well, you could just leave the machine on I guess, but other than that you'll get hit any time you do boot up. This is a chart of my CNC machine booting up where you may be able to see it establishing a net conneciton during the process:
img87.imageshack.us/img87/2250/wedoct27bootchart.png
Stuff like ifup, and dhclient3 are related to network connectivity. So you might want to configure your machine so it can connect, or it'll be something holding you up at times.
- Banana Jack
yeah... i'm working on that...
ArcEye wrote:
well i dropped my acceleration (yeah it was pretty up there, i don't know why...) but i can't figure out where those 42000s came from. i checked my setup, and they are actually dirhold 2000 dirsetup 2000, which is correct. i don't know why they show up in the hal file as 42000.
Try to find your drives here or search for a spec sheet for them.i don't actually know what those numbers mean...i may have just put them in myself while setting up.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Stepper_Drive_Timing
Yes, your velocity is 1" / sec which is 5ft / min, this is pretty much what my small stepper mill is set to (25mm in my case)so you think i should drop my acceleration?
However your STEPGEN_MAX_ACCEL is 37.5"/sec/sec which equates to 952mm . My mill runs smoothly with acceleration of 20mm/sec/sec.
I would just set your acceleration to 2" / sec to start with and then tune to suit
The thing that is going to affect your figures is the slow timing for the driver and the huge SCALE factor.
The first will limit the number of steps per second you can generate and the latter will require a huge number of steps to get anywhere.
Even if you have very fine ballscrews and high gearing on the stepper, I would guess you must have set micro-stepping very high, I would suggest that anything over 8:1 (1/8th step) is unnecessary and counter-productive and I rarely use higher than 4:1 (1/4).
One good reason for that, is that anything higher is interpolated positioning and no matter how good the driver it is far from precise.
Hopefully it will run now
and what is this scale you speak of? i have not heard of that. i'm currently half stepping though, if that makes any difference. and my steppers are directly driving my leadscrews.
SCALE is to do with the number of pulses it takes to move one machine unitwhat is this scale you speak of?
linuxcnc.org/docs/2.5/html/config/ini_co...d_sub_axis_section_a
However I was forgetting that you are using inches, we haven't used imperial units in engineering in the UK since the early - mid 70's
(although there was a long messy dual system period)
When your scale is divided by 25.4, then it comes out as something much more like I expected, so forget that, my brain failure.
Looks like you need to re-introduce the smi module now and see if your real-time errors go away
