No step pulse output from parallel port
- skarnsungen
03 Apr 2012 13:34 #18944
by skarnsungen
No step pulse output from parallel port was created by skarnsungen
Hi folks. Please help a EMC2/Ubuntu newbie...
Finished my EMC2 installation a couple of days ago and since then I've taken the first small steps into the fascinating world of EMC2. I think I've managed to set up a bootable configuraition with stepconf. But now I'm STUCK!
I'm getting no step output on the X, Y and Z step pins. The direction output works fine. I'm testing with a LED+resistor between pin 25 (GND) and the various output pins. I get a dim light shifting on the direction pins.
What I've tried regarding the step pins is:
-Set step pins to "inverted". The light comes on, at the corresponding pin and thus I suppose the parallel port is OK !?
-Measured voltage om the pins when moving position manually in the software. Result is unclear, I get seemingly systematic fluctuations but only around 25 mV in magnitude. Absolutely not sure I'm having any pulse activity!
-I've tried various settings of timing including the slowest possible settings of 0,5 sec
-I found a similar topic in this forum, mentioning the possibility of monitoring the pin values in the Hal-meter, but in my case this is not helpful as the window minimize everytime a setting is changed.
So any input is appreciated - how do I figure out what I'm doing wrong?
Thanks in advance
Peter
Thanks in advance
Peter
- BigJohnT
- Thank you received: 1176
03 Apr 2012 16:59 #18947
by BigJohnT
Replied by BigJohnT on topic Re:No step pulse output from parallel port
Step pulses happen pretty fast and you may not be able to see an led light up. The fact that you can see the direction pin change states is a good indication things are well. Do you have a driver or are you just experimenting with leds?
- skarnsungen
03 Apr 2012 17:33 #18948
by skarnsungen
Replied by skarnsungen on topic Re:No step pulse output from parallel port
Hi John
Thanks for your reply.
I do have a kind of driver. It's a homemade DIY design by Tom at: www.instructables.com/file/F5LOYU4F5R8QRL0. No timing info is supplied thoug. I've finished building the driver but when testing according to the mentioned procedure I do not get the supposed level-shifts on the IC pins - not even the input pins.
I'm now sure that there is some activity at the step pins as I can better registrer the voltage shift after raising the timing. You say that stepping happen very fast, but I thougth it was as simle as when I set step -timing and step space to 500000 ns I would get at pulse lasting 0,5 sec every 0,5 sec. Probably wrong???
As I'm now very much in doubt if I-m having a EMC2/ computer parport issue or the driver is the problem, Is there some way to find out? (other than buying a well tested commercial driver)
Kind regards
Peter
Kind regards
Peter
- Thank you received: 5262
03 Apr 2012 19:03 #18949
Replied by PCW on topic Re:No step pulse output from parallel port
500000 nS is still just .5 Milliseconds...
- arch dude
03 Apr 2012 19:41 #18950
by arch dude
Replied by arch dude on topic Re:No step pulse output from parallel port
If you do not have an O-scope, you can choose to build a trivial latch. Alternatively, you can learn enough about HAL to "build" a counter on an input pin and then connect your (physical) output pin to the (physical) input pin. You may also be able to use the HAL O-scope on the input pin: I have not tried this myself.
If you trust the software, you could simply use the HAL O-scope on the output pin.
- skarnsungen
04 Apr 2012 05:51 #18957
by skarnsungen
Thanks!!
Messed up the suffixes quite badly.
Of course 500000 ns is just 5 ms an not 0,5 s.
I do not have a scope and as mentioned I've not been able to use the HAL scope and I'm very far from beeing capable of understanding or editing HAL files myself.
I'm almost convinced that things are as suggested -that the time is just not long enougt to light up the LED, as I do see millivolt activity when jogging the axis. I'm going to dig a bit more in my controller function...
Kind regards
Peter
Kind regards
Peter
- cncbasher
- Thank you received: 288
04 Apr 2012 09:13 #18960
by cncbasher
Replied by cncbasher on topic Re:No step pulse output from parallel port
to test your hardware , with the controller connected up and power on , you should find that the stepper motor shaft is unable to be turned , i.e locked up
if the shaft can be turned then you have a fault .
if the above is correct and the shaft is locked up , then pulsing the step pin to ground ( i.e like tapping on a morse key ) you should have the stepper motor moving one step at a time as you pulse the input pin
the direction pin is either held at 5v or 0v to then reverse the stepper motor .
in the wicki their is a parrell port test application that may help , in a similar way as is described above
did you use step config to produce your parrell port config file ?
selecting the default configuration should work fine for your board
- skarnsungen
10 Apr 2012 18:37 #19107
by skarnsungen
Great info. THANKS!
I've found several issues regarding my driver board that have to be solved before any testing is possible. My counter IC's do not consequently count and the decoder IC's are not decoders due to a wrong subsitution by my supplier:unsure:
If correction of these subjects do not solve the problems, I'll go back to your test procedure.
I did use stepconf to set up the configuration. I believe the pin settings are not correct in any of the standard setups as my board have an "enable" input pin for each axis, but maybe I can use the same timing settings!?
Rgds
Peter
Rgds
Peter
- cncbasher
11 Apr 2012 07:34 #19123
by cncbasher
it's not required to use the enable , just make it permanantly enabled to start with , the enable for each axis can be tied to one pin later if needed ( i.e amplifier enable )
the default timing set up in stepconf should be fine for the boards you have , and initial testing
- skarnsungen
19 Apr 2012 05:34 #19367
by skarnsungen
OK I think I get you. I can use the timing settings but of course I still need to set up the pins according to my driver board. Thanks again.
Rgds Peter
Rgds Peter
Time to create page: 0.271 seconds
