new emc2 2.5.1 . error on axis x and y.
- RobotMatic
- Thank you received: 22
08 Aug 2012 20:35 #22980
by RobotMatic
new emc2 2.5.1 . error on axis x and y. was created by RobotMatic
new version 2.5.1 have a problem. The axis x and y are mirror in comparation with the home axis. the table of the machine is mirror before the home secuence.
!! we are change it?
- BigJohnT
- Thank you received: 1177
08 Aug 2012 20:56 #22981
by BigJohnT
Replied by BigJohnT on topic Re:new emc2 2.5.1 . error on axis x and y.
I have 3 machines running 2.5.1 and all act normally.
Did you upgrade from 2.5.0 to 2.5.1 via the software update prompt?
Did you change anything else when you upgraded?
- RobotMatic
08 Aug 2012 22:20 #22982
by RobotMatic
Replied by RobotMatic on topic Re:new emc2 2.5.1 . error on axis x and y.
my machine worked normally with 2.5.0.
Today Ubuntu updated to 2.5.1
when I started my emc2. The x and y axis changed the direction.
whit the stepconf wizard I changed the sign of the x and y axis direction.
my emc2 started apparently normal , I could run the home sequence, but when I tried to move the axis X and Y, I realized that the limits of the table were inverted.
I need a solution urgently
thanks !
thanks !
- BigJohnT
08 Aug 2012 23:43 #22984
by BigJohnT
It is very difficult to understand exactly what your problem is due to the language conversion. Have some patience and we will work this out. Of course the IRC might be faster depending on who is on line at the time.
1 When you home the X and Y axis do they go in the correct direction and home as before?
2 When you jog the X and Y axis do they go in the direction shown on this diagram ?
- RobotMatic
08 Aug 2012 23:55 #22985
by RobotMatic
linuxcnc 2.5.0 1 and 2 axis x and y work normally
linuxcnc 2.5.1 1 and 2 axis x and y work in opposite direction with the same .ini
- BigJohnT
09 Aug 2012 11:07 #22991
by BigJohnT
Can you zip up your config and attach it to a post?
- RobotMatic
09 Aug 2012 12:28 #22992
by RobotMatic
this is my ini and hal file.
- BigJohnT
09 Aug 2012 12:53 #22993
by BigJohnT
To test your config I need all the files from your config directory.
- RobotMatic
09 Aug 2012 13:13 #22994
by RobotMatic
i have two machine with this problem. i have two linuxcnc update 2.5 to 2.5.1 with this problem. it is very big problem
thanks
this is my folder conf
thanks
- RobotMatic
09 Aug 2012 13:36 #22995
by RobotMatic
when linuxcnc update 2.5 to .5.1 break the ini file. The solutios is make a new ini file.
thank for your time !!
Time to create page: 1.748 seconds
