new emc2 2.5.1 . error on axis x and y.
- BigJohnT
- Thank you received: 1176
09 Aug 2012 14:56 #22996
by BigJohnT
Replied by BigJohnT on topic Re:new emc2 2.5.1 . error on axis x and y.
Do you know what changed in the ini file?
The last files you attached is that the files after the 2.5.1 upgrade?
- BigJohnT
09 Aug 2012 15:07 - 09 Aug 2012 15:08 #22998
by BigJohnT
To recap and help us find what happened...
You created a config using the Stepconf Wizard in 2.5.0
You upgraded to 2.5.1
Did you run the Stepconf Wizard next or just run Linuxcnc?
Do you still have both copies of the .stepconf files in the config directory? If so can you zip them up and attach them to a reply?
I ran that config in both 2.5.0 and 2.5.1 with the direction of travel the same for X and Y axis.
Last edit: 09 Aug 2012 15:08 by BigJohnT.
- jwalter007
16 Dec 2012 01:08 #27775
by jwalter007
Replied by jwalter007 on topic Re:new emc2 2.5.1 . error on axis x and y.
I have 2.5.1 & my axis travel backwards. Can you tell me how to fix it?
- Rick G
- Thank you received: 155
16 Dec 2012 06:07 #27781
by Rick G
Replied by Rick G on topic Re:new emc2 2.5.1 . error on axis x and y.
If you want to change the direction your machine is moving try changing the sign of SCALE in your config file.
As an example if your scale for the axis you want to change is 5500 change it to -5500.
Rick G
Rick G
- Thank you received: 4992
16 Dec 2012 23:11 #27787
But be warned, you might be wrong. For example in CNC X plus == tool to right. In many cases this means table to left.
On my Mill X plus = table down...
Replied by andypugh on topic Re:new emc2 2.5.1 . error on axis x and y.
If it is a stepper system, and you configured with Stepconf, then just select the "invert" option for the Direction pin in the parallel port setup for each axis you want to reverse.I have 2.5.1 & my axis travel backwards. Can you tell me how to fix it?
Time to create page: 0.057 seconds
