Trying to configure Linuxcnc for a Syil SX3 mill
- MetalByter
25 Sep 2012 12:59 #24608
by MetalByter
Trying to configure Linuxcnc for a Syil SX3 mill was created by MetalByter
Hello, I am just starting off with LinuxCNC, I have it installed on an older Dell pc,
I have the pins set the same as they were in Mach 3, measuring the pins on the parallel port show that they are responding but there is nothing happening at the machine. I think there is a problem with the charge pump on pin 9. Is there a good known HAL file that works with A Syil SX3 ?
Has anyone managed to get a Syil SX3 running with LinuxCNC?
- BigJohnT
- Thank you received: 994
25 Sep 2012 13:15 - 25 Sep 2012 13:21 #24609
by BigJohnT
Replied by BigJohnT on topic Re:Trying to configure Linuxcnc for a Syil SX3 mill
You might try inverting the charge pump pin.
Do you know what the frequency requirement is for the charge pump?
If you used Stepconf Wizard the base period might be too long for the frequency needed by the charge pump.
I do see that Stepconf adds the charge-pump component and uses that but the man page is rather terse.
Last edit: 25 Sep 2012 13:21 by BigJohnT.
- MetalByter
25 Sep 2012 13:58 #24613
by MetalByter
Replied by MetalByter on topic Re:Trying to configure Linuxcnc for a Syil SX3 mill
Yes I have tried inverting pin 9 for the charge pump. and I don't know the frequency required.
I was hoping that somebody else had been down this road before. When I get home I will try to disable the charge pump at the machine.
If I can get any response it will be a starting point and a little more encouraging.
Mark
Mark
- BigJohnT
25 Sep 2012 14:05 - 25 Sep 2012 16:10 #24614
by BigJohnT
I did find out that the frequency of the charge pump is a function of the base thread and the typical stepconf base thread is 100,000 which would result in what Peter said in the next message.
A good page for charge pumps is:
wiki.linuxcnc.org/cgi-bin/wiki.pl?About_Charge_Pumps
You might need a shorter base period to get the frequency high enough to charge the charge pump.
Last edit: 25 Sep 2012 16:10 by BigJohnT. Reason: math error
- Thank you received: 5321
25 Sep 2012 16:02 - 25 Sep 2012 16:03 #24616
Replied by PCW on topic Re:Trying to configure Linuxcnc for a Syil SX3 mill
I think you have a small math-o here
if a typical base thread is 100,000 ns thats 100 us or .0001 second
so
1/(.0001 X2) = 5 Khz
so
Last edit: 25 Sep 2012 16:03 by PCW.
- BigJohnT
25 Sep 2012 16:08 #24617
by BigJohnT
I sure am glad someone came along that knew what they were talking about...
Thanks for the correction Peter.
25 Sep 2012 16:37 #24619
Well I learned to watch decimal places from using a slide rule
(I guess that places me firmly in geezerhood)
- MetalByter
20 Oct 2012 17:23 #25493
by MetalByter
Thank you for the help and quick responses,
Unfortunately other things have taken much of my time. I have disabled the charge pump on my machine
but still no movement. I checked the pins on the parallel port the input seems to work but the output pins do not. I think the problem is in the set up of the Computer. PS2 DMA3. Any idea on how to get the port to work correctly. This is an older Dell Dimension 3000 P4.
Mark
Mark
- MetalByter
20 Oct 2012 22:43 #25512
by MetalByter
Making some progress, did a reinstall and got the parallel port set up, my scope now shows a signal at the cable on the step pin of the X axis. has any body here have some experience with the syil drivers?
I will have to check inside the mill it has been running fine for years on Mach with no problems.
Mark
Mark
- Thank you received: 4652
21 Oct 2012 01:03 #25524
Replied by andypugh on topic Re:Trying to configure Linuxcnc for a Syil SX3 mill
MetalByter wrote:
If it is trivially easy to try the Mach config again then that might be a test worth doing. It is conceivable that a hardware problem has occurred just at the same time as your software switch.
I think JT has a utility that can make a stepconf file from a Mach XML, which might also be worth a try.
My machine (not a Syil) didn't work until I inverted the step pins. That's probably worth a try.
That would seem to indicate that the problem is something to do with the LinuxCNC config.I will have to check inside the mill it has been running fine for years on Mach with no problems.
Time to create page: 0.132 seconds
