HP-copaq NC8000
29 Oct 2012 20:09 - 29 Oct 2012 20:12 #25995 by TAREQ_BELAL
HP-copaq NC8000 was created by TAREQ_BELAL
Hi every one
I have an HP-COMPAQ NC8000 laptop
I was using it with Ubuntu 8.04 with EMC2.3.0
i was running very well but after setting up the UBUNTU 10.04 with linuxcnc 2.5
i wade an error message and don't how to report it to the support
can you help me???
Last edit: 29 Oct 2012 20:12 by TAREQ_BELAL.
29 Oct 2012 20:44 #25996 by BigJohnT
Replied by BigJohnT on topic HP-copaq NC8000
If your laptop is old it is possible that you can't run 10.04... in any case we can't read your mind you will have to tell us what the error is.
The following user(s) said Thank You: TAREQ_BELAL
29 Oct 2012 21:19 #25997 by TAREQ_BELAL
Replied by TAREQ_BELAL on topic HP-copaq NC8000
Thank you for attention
the ubuntu 10.04 is working good but when i start the linuxcnc program the problem occures
the question is How to copy the error message to send it?
29 Oct 2012 21:23 #25998 by BigJohnT
Open up a terminal and type in dmesg > error.txt and a text file will be created. Using the Reply button attach the file to a message.
29 Oct 2012 23:12 #26001 by ArcEye
Replied by ArcEye on topic HP-copaq NC8000
You will need to boot up, try to run Linuxcnc , then do this immediately afterwards or the error messages will not be there.
30 Oct 2012 03:18 - 30 Oct 2012 03:49 #26012 by TAREQ_BELAL
File Name: LinuxCNCerror.txt
File Size:53 KB
I think this is the file
I hope it work
Last edit: 30 Oct 2012 03:49 by TAREQ_BELAL.
30 Oct 2012 03:28 #26014 by TAREQ_BELAL
please tell if this is the right file you want?
30 Oct 2012 03:56 #26016 by TAREQ_BELAL
File Name: linuxcncerror.txt
File Size:55 KB
another file
30 Oct 2012 03:58 #26017 by TAREQ_BELAL
see you tomorrow coz i have to sleep now
thank you my friends
30 Oct 2012 04:33 #26020 by BigJohnT
Open up a terminal and type in uname -a and tell us what it reports for the kernel name.
