Mill jumping but LinuxCNC shows correct path
08 Jan 2013 04:54 - 08 Jan 2013 06:08 #28474 by thegrandwazoo
Mill jumping but LinuxCNC shows correct path was created by thegrandwazoo
Hi all! I am new to LinuxCNC and new to CNC as a whole but making great strides! I have been able to get to this point without asking for help but it seems that time has passed. :)
I am trying to cut a 3d part.
I setup, home and touchoff the part. Start running the program and everything looks great for 3 complete passes of the code. Once it gets to the 4th pass .03 into the part the mill the jumps to a different spot on the material ruining the part. It jumps to the same spot each time but Axis shows the correct spot on the material.
I have tried this using 2 different tool paths generated by 2 different CAM apps (MeshCAM and HEEKS)
I have tried:
G92.1
G54
G49
running relative coordinate display
And I get the same behavior each time I attempt to cut this part.
Any help would be HUGE!!!
Many thanks,
The Wazz
Edit/Delete Message
Last edit: 08 Jan 2013 06:08 by thegrandwazoo.
08 Jan 2013 05:45 - 08 Jan 2013 05:45 #28478 by BigJohnT
Replied by BigJohnT on topic Mill jumping but LinuxCNC shows correct path
Looks like lots of guessing going on... can you post a short example of the G code that does not give you what you expect?
What is your preamble?
Have you seen my tutorial on G code?
Last edit: 08 Jan 2013 05:45 by BigJohnT.
08 Jan 2013 05:58 - 08 Jan 2013 06:03 #28481 by thegrandwazoo
Replied by thegrandwazoo on topic Mill jumping but LinuxCNC shows correct path
Gcode attached. (Not letting me attach the file)
The issue starts somewhere around here:
X0.0039 Y2.4382 Z-0.0261
X0 Y2.4382 Z-0.0267
X0 Y2.4421 Z-0.0277
X0 Y2.5817 Z-0.0277
X5.5121 Y2.5817 Z-0.0277
X5.5121 Y2.7251 Z-0.0277
X0 Y2.7251 Z-0.0277
X0 Y2.8685 Z-0.0277
X5.5121 Y2.8685 Z-0.0277
G00 Z0.1987
X0 Y0
Z0.0509
G01 Z-0.0376 F3.93
X3.1318 Y0 Z-0.0376 F8.44
X3.1397 Y0 Z-0.0334
X3.1554 Y0 Z-0.0239
X3.1869 Y0 Z-0.0136
X3.2026 Y0 Z-0.0113
X3.2341 Y0 Z-0.0105
X3.899 Y0 Z-0.0112
X3.9541 Y0 Z-0.015
X3.9895 Y0 Z-0.0198
X4.0131 Y0 Z-0.0246
X4.0288 Y0 Z-0.0291
X4.0446 Y0 Z-0.0376
X5.5121 Y0 Z-0.0376
X5.5121 Y0.1434 Z-0.0376
X4.8354 Y0.1434 Z-0.0376
X4.8275 Y0.1434 Z-0.0329
X4.8197 Y0.1434 Z-0.029
X4.7921 Y0.1434 Z-0.0218
X4.7567 Y0.1434 Z-0.0163
X4.7174 Y0.1434 Z-0.0127
X4.678 Y0.1434 Z-0.011
X3.2774 Y0.1434 Z-0.0107
X3.2538 Y0.1434 Z-0.0126
X3.2341 Y0.1434 Z-0.0172
X3.2065 Y0.1434 Z-0.0295
X3.1947 Y0.1434 Z-0.0372
Preamble:
(Created with emc2b post processor 2013/01/02 09:18)
G64 P 0.0001 Q 0.0001
G54 (Select Relative Coordinate System)
(tool change to 1/4 inch HSS End Mill)
T1 M06
G17 G90 G20
I also was using MDI to run G92.1, G40, G49 and the like.
I have not read your tutorial but I will tonight. I have been RTM for the app that is where I tried "So if your lost what should you do" with no joy.
Thanks again!!!
Last edit: 08 Jan 2013 06:03 by thegrandwazoo.
08 Jan 2013 06:32 - 08 Jan 2013 06:32 #28482 by BigJohnT
That all looks normal to me and your using G64Pnn so that is good too. If this is a stepper machine I'd suspect missing steps.
The file size limit is 1600Kb.
If this is a stepper machine run the stepper diagnostics from the manual.
Last edit: 08 Jan 2013 06:32 by BigJohnT.
The following user(s) said Thank You: thegrandwazoo
08 Jan 2013 06:39 #28483 by thegrandwazoo
OK cool I will try that and report back!
Thanks again!
08 Jan 2013 06:43 - 08 Jan 2013 10:06 #28484 by thegrandwazoo
Well my file size is 1695Kb so that may be it. If it exceeds the file size limit how do I work around that? Do I create a second file to complete?
ETA: I thought you meant that LinuxCNC had a file size of 1600Kb not the forum upload. I am just a little slow today...
:P
Last edit: 08 Jan 2013 10:06 by thegrandwazoo.
08 Jan 2013 06:49 #28485 by BigJohnT
Compress the file as a zip.
08 Jan 2013 17:56 #28491 by Rick G
Just to confirm ...
With the program running
After this happens if you use mdi to return to a know location say X0Y0 is it off by the amount of the "jump"?
Rick G
09 Jan 2013 09:18 #28508 by thegrandwazoo
Have not tried to see. I will give it a go and report back.
09 Jan 2013 12:33 #28510 by thegrandwazoo
Just to confirm ...
Rick G
Yes it returns to the "jumped to" position as the new (wrong) X0Y0. Axis still shows the correct YX.
Thanks again for your time guys!
-Erick
Time to create page: 0.092 seconds
